Old 07-23-2006, 05:43 AM   #1
Safe amout of boost
My Ride: 1986 Dodge Omni GLH
Engine: 2.2 135c.i
Hello, i was just wondering what is the stock amount of boost a 1986 dodge omni with a turbo one setup will put out, also what is the safest amount you can make this turbo produce without causing damage, is 10-12 to much, i need help with this one, i don't have that much knowledge on this one.
Zenarc is offline
Old 07-23-2006, 05:59 AM   #2
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Should be around 11 stock.. I've heard of people running 14 on a log without a problem. They may have been running like 94 octane which isn't available everywhere.. What's the best you can readily buy in your area? How many miles are on your engine? Seems as they get older and have more blowby, you can get away with running more boost because the effective compression is lower.. haha..
Una is offline
Old 07-23-2006, 06:49 AM   #3
My Ride: 1986 GLHS #126
Engine: stock
weren't the '86 TI's 9 psi engines?
or were they 7 psi? it's one of those but not 11 psi right?
there's numerous questions like yours ZENARC on "what is the most boost i can run safely", and there is going to be a lot of different answers/opinions you will get.
the T1 engine is a 2 bar logic module/MAP sensor meaning the computer can only adjust fuel/spark curves for boost up to 14.7 psi, so thats one limitiation. also, your TI is not intercooled, so the temp. of the intake charge is also something that will limit the "safe boost" on your engine otherwise you risk detonation and damage to pistons. etc.
with no intercooler and no additional fuel system upgrades i would put the safe boost cap on a '86 TI at 12 psi. max.
Marcus86GLHS is offline
Old 07-23-2006, 08:26 AM   #4
Una
Engine: 2.5L Turbo
Yeah, I think you're right on the 7-9psi.. I think the MP module turned it up to 11 though..
Una is offline
Old 07-29-2006, 04:03 PM   #5
My Ride: omni
Engine: megasquirted 2.2
intercooled and with +20 injectors i run 20 with no problems at stock fuel pressure
never had a non intercooled omni, but they are always going to be slow unless you alcohol/water inject them so id just forget about doing anything until you intercool it. the cars quickly become monsters for what they are with just a little bit of work
saw wave analog is offline
Old 07-29-2006, 06:03 PM   #6
Una
Engine: 2.5L Turbo
Always slow? Bah.. I ran 14.9 non intercooled in my Omni.. Not wicked fast, but definitely not slow either.
Una is offline
Old 07-30-2006, 03:32 AM   #7
My Ride: omni
i guess its just all relative. 13's is kind of my threshold for calling something quick.. i dont think i could ever get excited about a 15 second anythin g regardless of what it ran stock
there was a guy on here that ran a 12 something non intercooled wasnt there? i dont remember if he was using water injection or not but i remember seeing some impressive time out of a hot piped omni
my point was just that its so cheap and easy to intercool an omni that i dont see the point in running on the edge to squeeze out a high 14 when you can safely run mid 13's all day for just a couple hundred bucks for the tII stuff and some decent tires
the seat of the pants diofference between 14.9 and 13.5 is definately worth the effort imo hehe
Loans | Credit Card Consolidation | Cheap Hosting | Debt | Agencia de turismo
Page generated in 0.46250 seconds with 13 queries
