what cleans the head gasket surface the best? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 25 Old 08-06-2006, 11:55 PM Thread Starter
My Ride: 89 Daytona Shelby!
Engine: Turbo II
i am putting my head on and was wondering if there are any great cleaners out there to clean my old compressed HG residue off of the block surface?
parker87 is offline
post #2 of 25 Old 08-07-2006, 02:53 AM
mock_glh's Avatar
My Ride: '85 Omni
Engine: 2.5L
Lightbulb
Elbow grease and a sharp scraper.
mock_glh is offline
post #3 of 25 Old 08-07-2006, 07:29 AM
ABSOLUTELY CORRECT. you can also buy some gasket removal spray. any auto parts store will carry this. it helps if elbow grease is something you don't have much of.
22dodge is offline
post #4 of 25 Old 08-07-2006, 07:37 AM
Yeah, a nice sharp scraper will work great. Just be careful when scraping old gaskets off aluminum!
DaytonaTurboZ is offline
post #5 of 25 Old 08-07-2006, 07:52 AM
- OFFICIAL GEARHEAD -
My Ride: Ram HFE/Omni/SL/XR7
Engine: 2.5 TII+SMEC+.60/.63+2-piece+SRT4 IC+no B/S ;)
die grinder & a small wire wheel ? then starting fluid, then rubbing alcohol
then pour oil in cylinders and crank engine by hand to scrape up gasket and other misc. residue, wipe off with rag
gasket removal spray is awesome for real baked on shtuff; burns when you get it on your hands
detobias is offline
post #6 of 25 Old 08-07-2006, 10:28 AM
Garrett Booster
My Ride: 88 ram 3/4 ton
Engine: 360
wow, you guys love the hard way.
cookie wheel, for the win
DomChassis is offline
post #7 of 25 Old 08-07-2006, 11:25 AM
Hybrid Booster
My Ride: '89 Sundance RS
Engine: 2.5L SOHC 8 valve
drill or dremel with a green scotchbrite pad.....works beautifully.
Clay showed me that one.
3Bar_Mopar is offline
post #8 of 25 Old 08-07-2006, 01:03 PM
TD Hardcore User!
My Ride: 1994 Caravan turbo!
Images: 4
Heh, I used a scraper and then Windex because it was the only alcohol based solvent I could find.
big_P is offline
post #9 of 25 Old 08-07-2006, 01:14 PM
My Ride: 1987 caravan
Engine: 2.2 carb
Pete,
Windex is water & sudsging ammonia, with touch of coloring fluid.
Doesn't cut grease/oils very well.
Cheers, Wizard
Wizard is offline
post #10 of 25 Old 08-07-2006, 01:31 PM
All manufacturers strongly advise against cookie wheels to clean aluminum heads. I was in my friends machine shop and he showed me a honda head some kid used one of them on an air die grinder, .020-.025 divits in the aluminum
22dodge is offline
post #11 of 25 Old 08-07-2006, 02:11 PM
My Ride: 5 TD's
Engine: 2.2, 2.5
I don't use a scraper! There are special wheels available for cleaning gaskets off aluminum! They are available at NAPA and most other reputable auto parts houses. Cylinder heads have a special machined service to allow for movement. You don't want to put divots in the head.
Guy
guyd_15 is offline
post #12 of 25 Old 08-07-2006, 05:42 PM
TD Hardcore User!
My Ride: 91 Spirit,87 ShelbyZ
Engine: 2.5n/a, 2.2t2
Images: 9
sharp razor, carb cleaner, green scotchbrite pad, tough paper towels/rags
RPMurph is offline
post #13 of 25 Old 08-07-2006, 11:08 PM
Garrett Booster
Engine: 360
don't use cookie wheels is a "general public" warning. Even the plastic ones with the nubs will remove material from you head if you an asshole with them. Hell, anything you use that has any grit or metal like a scraper will remove metal. If you suck at workin on cars, use elbow greese. If you don't then use a regular cookie wheel. I have never had any problems with blending any of the machined RA from a head, and having a gasket fail.
post #14 of 25 Old 08-07-2006, 11:08 PM Thread Starter
Engine: Turbo II
thanks guys, i love you guys
parker87 is offline
post #15 of 25 Old 08-08-2006, 10:50 AM
Opossum fat and lye. Yup!!! Oh, and a Scotch Brite pad.
John O
PUNKslip is offline
Human Verification
