Old 08-28-2006, 04:07 PM   #1
Holset Oil feed lines
Hybrid Booster
My Ride: Magnum
Engine: 2.5 TII
Hi all...
Does anyone knows were I can find some feed lines for the Holset turbo ?
I want to buy something like a kit to feed my turbo (Holset HY35w) because Im tired of been looking without any luck...
Here I can only see DIY turbo kits for ricers
btw, somewhere I've seen that I need an oil restrictor for the feed line... is that true ?.... according to that If i dont use the oil restrictor the turbo will smoke during the break-in process.
Any help will be appreciated.
My car is a Spirit 2.5 CB 8v head.
Thanks.
R/Tony is offline
Old 08-28-2006, 11:08 PM   #2
use this fitting and a -4 AN braided line: http://store.summitracing.com/partde...=KeywordSearch
A restrictor is not necessary, and turbos dont need any sort of break-in.
xrattiracer is offline
Old 08-29-2006, 11:02 AM   #3
Hybrid Booster
My Ride: Magnum
Engine: 2.5 TII
Thanks...
About the restrinctor I've found this: http://www.dsmtuners.com/forums/showthread.php?t=171317
What do you think ?.
thanks
R/Tony is offline
Old 08-29-2006, 01:48 PM   #4
so far as i know a turbo has never failed from having too much oil. I certainly dont use a restrictor with my holset, and neither does anyone else i know.
And i would NEVER restrict the oil supply without having a pressure guage after the restrictor. How much boost the turbo can handle before bearing failure is a direct relation to thrust bearing surface area and oil pressure. I would rather have "too much" pressure than not enough.
Old 08-29-2006, 03:31 PM   #5
Hybrid Booster
My Ride: Magnum
Engine: 2.5 TII
Yeah that sounds logical to me... I would rather have oil too.
btw what is the max oil pressure for the Holset turbo ?
Thanks
R/Tony is offline
Old 08-29-2006, 04:13 PM   #6
Authorized TD Vendor
mopar2ya's Avatar
My Ride: 91 Spirit R/T
Engine: 2.2 TIII
Im using the SS line that FWDP sold me for my hybrid.
Wallace
91 Spirit R/T
11.686@120.89 mph
mopar2ya is offline
Old 03-26-2008, 10:03 PM   #7
Re: Holset Oil feed lines
My Ride: 88 DOHC Pacifica
Engine: 2.5L
I felt this thread was missing something so here we go.
Holset repair manuals
http://www.holset.co.uk/pics-related...%20manuals.php
Steps 12, 13, &14 address the oil pressure related questions.
MachIIIRayzor is offline
Old 03-27-2008, 03:54 PM   #8
My Ride: DOdge Shadow ES
Engine: 2.5l
I should have looked at that manual again before I made my oil drain. O well, I don't think the -16 is going to hurt anything.
DJ
turboshad is offline
Old 03-27-2008, 05:13 PM   #9
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
Thats just crazy!!
speeduphoria is offline
Old 03-27-2008, 06:46 PM   #10
My Ride: 91 Daytona
Engine: 2.4
im running a -4 feed, -12 return
Rock Kustoms is offline
Old 04-01-2008, 08:48 PM   #11
My Ride: 82 Rampage
Engine: 2.4 16V turbo. NGC M
I'm running a 6an feed and 12 return
Dean Stillie is offline
Old 04-03-2008, 04:30 AM   #12
My Ride: 88 daytona shelby
Engine: 2.2l
im running a -6 supply and stock return never ever sees under 50psi oil pressure
zach is offline
Life Insurance | Mortgages | Cheap Loan | Loans | Leicester City
Page generated in 0.41868 seconds with 13 queries
