Old 11-06-2006, 07:16 PM   #1
raising boost cut-out
My Ride: 1999 Integra GSR
Engine: 1.8 DOHC VTEC
I want to run more than 11psi on my 86 turbo z. How do I move the cut-out to 14.7 like the later model cars? Would a map clamp work? I dont want to remove the cut-out cuz I dont want it to spike when Im watching the road and blow my motor
89CSX#179 is offline
Old 11-06-2006, 08:20 PM   #2
My Ride: 1989 TurboI Daytona
Engine: 2.5 intercooled
i just shortend my waste gate arm or made it adjustable the computer will still let you push 14 no problems, BUT!!!!!!!!!! don't go more than 12 with no intercooler or some sort of chem cooling.
azkcar135 is offline
Old 11-06-2006, 08:36 PM   #3
speedyshelby16's Avatar
My Ride: Shelby Charger
Engine: 2.2 turbo II
Images: 8
grainger valve it. The cut is still 14.7 just the stock computer keeping it at 11.
Check them out.
speedyshelby16 is offline
Old 11-06-2006, 08:44 PM   #4
then why do I hit cut-out at 11 even WITH the grainger
Old 11-06-2006, 08:57 PM   #5
Images: 8
What your boost gauge are you using the stock ones aren't very good. What does it feel like? Does it buck and cutout or is it just don't make anymore?
Check them out.
Old 11-06-2006, 09:01 PM   #6
bucks HARD then keeps going for a few seconds and will buck again HARD
Old 11-06-2006, 09:19 PM   #7
My Ride: 89 omni & 90 T1 shad
Engine: 2.5L HX-35 w/alcohol
thats cut out! if its cutting out and only reading 11psi on your stock gauge, your gauge is out!
turbo minivan is offline
Old 11-06-2006, 10:28 PM   #8
ok, this is what happened. I bought the car, it ran stock psi (7 with spikes to 9). I put the grainger on it and set it to what I thought would be 12 psi on the stock gauge. THIS WORKED for about 2 1/2 weeks THEN it started overboosting. Now whenever the gauge hits the same area that it WAS working before, it cuts out. So WAS my gauge good and it just recently broke or was it bad and my computer just start catching up?
Old 11-06-2006, 11:16 PM   #9
sounds like your gauge is bad! the 4.3v diode was easy to put in for me and stopped the over boost when spiking.
Old 11-06-2006, 11:29 PM   #10
Images: 8
I got a diode on SC that allows me to got 16. I kill the headgasket in no time on the stock injectors. I got some laying around I bought package of ten and only used one.
Check them out.
Old 11-07-2006, 12:28 AM   #11
Jay
My Ride: 89 turbovan
Engine: 2.5 CB
Images: 2
this will work the best
http://cgi.ebay.com/ebaymotors/ws/eB...m=250047063441
Jay is offline
Secured Loans | Personal Finance | Mobile Phone | Mortgages | Debt Consolidation
Page generated in 0.92016 seconds with 13 queries
