Old 02-28-2007, 05:30 PM   #1
T3/T4 same as HY35?
Hybrid Booster
My Ride: 89 omni & 90 T1 shad
Engine: 2.5L HX-35 w/alcohol
what are the size difforences between a T3/T4 and an HY/HX 35? i read some place they are practicly identicle as for A/R ratios and such. also, is it true that an HY-35 will bolt right up to a T3 exhaust manifold flange?
turbo minivan is offline
Old 02-28-2007, 07:26 PM   #2
My Ride: 89 Chrysler Daytona
Engine: 88 2.2 T1-T2 upgrade
Well it depends on what T3/T4 your talking about. I dont think the turbos are alike at all, but I dont have either to compare so take that how you want to.
daytonajesse is offline
Old 02-28-2007, 07:28 PM   #3
Level 1 Supporter
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (13)
quite different and the Holset is larger than a T3/T4 we might run on an 8v
xtrempickup is offline
Old 02-28-2007, 08:22 PM   #4
Will Martin's Avatar
My Ride: '92 IROC R/T
Engine: 2.2 135ci TIII 16v
Here's a picture of a Holset (I think it's an HY 35), a Precision T3/T4 ceramic dbb 50 trim stage III turbo, and a .48 T3/T4 stage III turbo. Notice how big the turbine housing is on the Holset.
Will Martin is offline
Old 03-01-2007, 12:57 AM   #5
thats not a HY. easy to tell though by looking into the turbine inlet. if its split scroll, then its no an HY. They are certainly larger than a T3 hot side, but not by a huge amount.
xrattiracer is offline
Old 03-01-2007, 09:00 AM   #6
Okay then, it's not an HY. HC maybe? All I know is that it's a freakin' Holset and it's huge. The person running it was running 10's so it got his car that fast and it worked. I've since sold it so I can't remember which series it was.
Old 03-01-2007, 10:44 AM   #7
My Ride: Magnum
Engine: 2.5 TII
Its true... at least the HY35 has a T3 flange.
This is my Holset HY35 compared with a KKK (Vag's turbo):
R/Tony is offline
Old 03-01-2007, 11:46 AM   #8
My Ride: 2004 SRT4
Engine: 2.4
Feedback: (-1)
The HX35 and the H1C and WH1C (the only difference on the last two is the W one has a wastegate.) all have the standard T3 flange.
Andre Parker is offline
Old 03-01-2007, 02:20 PM   #9
My Ride: 88 Shadow
Feedback: (7)
Correct. The HY35 has a considerably smaller turbine section than the HX and h1c's, smaller housing and wheel which makes them a better condidate for four cylinders. The HY35 has a 9cm housing, the HX35 has a 12cm divided housing. The HY35 has a slightly smaller compressor, but I know the HX35 outlflows a 57 trim T4!!! Mopar2ya has also said in a thread in the cummins section that the 9cm housing is equal to about a .7X turbine in garret lingo.
So, get an HY35 for about $200 and use the money you saved on the turbo to get a TU header with T3 flange. Should make for a killer setup. You will need a TU header to run the HY35, the compressor is too large. You probably couldn't run a TU header and HY35 on a L body car either, it would hit the brake booster.
Matt
87' Daytona
T2 conversion, stock rebuilt 2.2 T2 engine, TU 3 bar +40's cal, ported G head, 88' roller cam, 2 piece intake, 3'' exhaust, ported exhaust manifold, S70 w/.63 stage 1, dual core IC, UDP, A520 trans w/moly plate, 8 puck clutch.
260 WHP, 317 ft/lbs@19 PSI and only 4 degrees advance on the timing (found out later my timing light was off)
Looking to crack 300 WHP at 22 PSI on pump gas
moparzrule is offline
Page generated in 0.17269 seconds with 11 queries
