03-21-2007, 12:36 AM
Wierd Hybrid turbo failure
My Ride: 89' Dodge Daytona ES
Engine: 2.5 l4
Hi guys!
its a two month built turbocharger garret 42 48 converted to stage 3 exhaust and t5 sixth compressor wheel, was running great @16 psi until today i started hearing a wooooooooo sound when i was suposed to go in boost so i backed of came home and checked the turbo, the shaft dosnt play side by side or up and down but if i pull the shaft it will almost pop out and go back in making a sound like if it was loose, any toughts?
03-21-2007, 09:31 AM
My Ride: 86 S/C
Engine: 2.2 8V
Sounds like your thrust bearing went south.
Robert Mclellan
[SIGPIC][/SIGPIC ]
03-21-2007, 09:48 AM
Engine: 2.5 l4
is that expensive to repair?
03-21-2007, 08:10 PM
Engine: 2.5 l4
anybody know why a turbo would fail in such shot period of time, i always let it cool on shutdown and i always had good oil oil lines were new mabe the setup?
03-21-2007, 08:53 PM
NO Democracy!
Chris at TU has mentioned in the past the the other braided SS oil/coolant lines sold by others have a very small ID in them. Because of this, TU sells a different SS line kit that supposedly has a much larger ID. That could be a culprit... but FWD sells the other style and I figure if it was a major issue, they would be replacing them with larger ID as well. Food for thought.
2nd thing I have heard about is the oil filter/restrictor that turbonetics installs on their turbos. Some people have witnessed issues with this, but not quite like what you are having...I think their's was oil smoking...I think. It is a thread here and on T M I think if you search hard enough from about a year ago.
Lastly... I have heard some bad things about turbonetics in the past 2 years. Some crappy turbos have reportedly come out of there.
This is all what I have read in the forums anyways.
03-21-2007, 09:40 PM
Engine: 2.5 l4
god this sucks
03-22-2007, 06:11 AM
Yeah, and small feed lines for the oil are NOT an issue. Turbo will be happy with not seeing much oil pressure or too much volume.
oil smoking.....um, That would have absolutely nothing to do with a restrictor/filter.........more like an issue if you DONT have one in certain applications.
03-23-2007, 06:40 PM
#12
Engine: 2.5 l4
[ATTACH][ATTACH] DSC00058 (Small).JPG[/ATTACH][/ATTACH]
theese are the images of my turbo when built in december
03-28-2007, 06:14 PM
#13
update
Engine: 2.5 l4
Hi guys got the turbo out today, compressor wheel was completely eaten, i think clearance issues migh have caused it since the car wasnever really used since this month, also note i was using a cone filter and cai.
im heading tomorow to the turbo builder
03-31-2007, 10:11 PM
#15
My Ride: 88 Shadow
I agree, it's done.
