07-14-2007, 06:54 AM
Welcome to the board. This post is a little wordy, but please read it and then maybe you'll understand why not only do you not need a blow off valve, but also why it won't even work on your car.
Blow off valves are to relieve pressure from the output of the turbo when the throttle plate is shut (like when you shift gears and let off the gas when in boost). On later non-log type turbo motors (1988 and up), the throttle plate closing causes all of the boost pressure in the piping between the turbo and throttle body to have no where to go. So it gets forced back towards the turbo (sort of). This causes the turbo to want to slam to a screeching halt and then spin backwards! This kills the bearings and seals and really shortens the life of the turbo.
Now, on an early T1 with a log intake like you've got, it's a completely different setup. The throttle plate is actually before the turbo. This means that instead of the turbo sucking in fresh air and compressing it and forcing it through piping to the throttle body like the 1988 and later motors, your turbo actually sucks the air through the throttle body and then compresses the air and forces it directly into the engine. So when you let off the gas and the throttle plate closes on your car, all that happens is the turbo can't suck in any air. All the pressure that the blow off valve would be used to release is on the output side of the turbo and gets sucked right into the engine.
Long story short, not only do you not need a blow off valve, if you installed one on your motor, it wouldn't make the sound you're looking for anyway! There's never any built up pressure for it to "blow off".
Jon
85 GLH-T
86 GLHS #141
