08-21-2007, 07:36 AM
My Ride: OMNI, ShelDak, TSi
Engine: 2.2 'GLHS style' TII
Originally Posted by moparfwdsleeper
Either way a FWD-P or a custom chipped cal i'd recommend a 2 or 3 bar MAP. Going fast cost money, the less you spend now the more you'll wish you would have spent later on.
I think sleeper meant he would recommend a 3 bar map, since you already have a 2-bar, and you said you wanted to go above 14.7 psi -which is above the range of a 2-bar
certainly a 3-bar map and custom cal (once optimized, which may take an iteration or two with the vendor) would be the simplest option, most user friendly, but expensive; probably the best solution if you plan to go >18-20 psi
if you dont have the money, like some of us, then you are forced to go old school and play with zeners, 5th injectors, AFPRs for tuning, and/or other tricks.
a zener diode is the *cheapest* cut-out eliminator (I got mine for free) but you have to TUNE SMART: be careful when raising boost, watch your plugs, A/F, EGT, ... works for me but I never go above 15psi and mainly added mine so I could run 13-14 without the occasional aggravating overboost shutdown
