Old 08-27-2007, 11:54 AM   #1
best way to get more boost?
My Ride: 85 laser
Engine: 2.2 turbo
i have an 85 charger with an 88 commonblock motor in it. i got full three inch exhaust no cat no muffler, a mp stage 2 LM, + 20's and my 255 fuel pump will get put in this weekend. i got a grainger valve in it right now set at 14 psi. i was really wanting to see 18 or 20 psi out of the car before its time to park it for the winter, i have read about bleeds and diodes and shimming wastegates and of course a cal. my question is whats the easiest way and the safest way to do this. the motors got about 3500 miles on the rebuild adn i dont wanna hurt it. any advise would be much appreciated.
Thanks
Andy
sleepinlaser is offline
Old 08-27-2007, 01:04 PM   #2
My Ride: '86 Omni GLH-T
Easiest way: Zener diode ($10) or Fuel cut raiser from 3bar Racing ($40)
Safest way: Custom cal from FWDP or TU
Edit to add: The custom cals are as straightforward as it gets, just plug and play. You'll need a 3bar MAP sensor though if you plan to run more than 14.7lbs. They're going to cost you more though, you're looking at $125+ for a reliable cal. The 3bar sensor will put you back another $70.
anokabball24 is offline
Old 08-27-2007, 02:26 PM   #3
My Ride: '90 Voyager
Engine: 2.5 16V Twin Mitsus
Easiest and safest is the custom cal. If your final goals are 20 psi, get a 3 bar map and a custom cal set for that boost, plug them both in, and you're done. No messing with diodes or map bleeds, you'll get the right spark/fuel curves, and it'll be much more reliable in the end. Just make sure you don't end up maxing your injectors if you ever decide to run more boost.
90TurboVan is offline
Old 08-27-2007, 08:33 PM   #4
Feedback: (32)
Best way?
Buy a wideband o2 sensor.
tryingbe is offline
Remortgages | Charity | Loans | Online Loans | Car Insurance
Page generated in 2.52050 seconds with 13 queries
