Old 11-30-2007, 10:46 AM   #1
Exclamation too much boost? need help fast
My Ride: 85dodgeshelbycharger
Engine: 2.2 turbo
i have a 1985 dodge shelby charger with the the 2.2 and im puting out 12.5 psi of boost but i have a 4inch down pipe with a stoped up cat if i run open down pipe at the drag races sunday will that be too much boost? any clues on how much boost ill be puting out
brad horton is offline
Old 11-30-2007, 02:03 PM   #2
Re: too much boost? need help fast
My Ride: Dodge Daytona
Engine: Turbo 2.2
Im going to try and help. This will probably help others help you, and me lol.
Do you have a boost gauge?
I think at 15 if your running a stock computer u will hit overboost.
If you have a manual boost controller you'll be fine and able to tune in the amount back to 12.5.
It will change the amount of boost because the turbo will spool easier and you will probably spool sooner and faster. It will go up, but how much I can't tell you.
Bbneon95 is online now
Old 11-30-2007, 05:20 PM   #3
Engine: 2.2 turbo
i do have a boost gage however i do not have boost controler so i as long as i dont hit 15 psi im good right?
Old 12-05-2007, 03:42 PM   #4
Garrett Booster
My Ride: 1990 Voyager
Engine: 2.5L
If you hit 15 PSI, you might also hit the windshield
Thats cause at 15PSI the fuel cut happens,.
I hit it a few times....fun stuff.
So to answer your question , yes ,you will be ok b/c your car should limit boost to 15 PSI
Over 15 PSI and you will need to add fuel so that you dont run lean and cause possible engine damage.
Good luck!
Scott
Domesticboost is offline
Old 12-05-2007, 10:44 PM   #5
My Ride: 87 GLHS
Engine: 2.2 16V Maserati
Keep in mind boost presure is a measure of how much air CAN'T get through the motor. So more than likely, if your cat is plugged and you remove it, your boost will go DOWN not up. Don't despair though, you will make more power at a lower boost level if you ditch a cat that is plugged Now if you used a manual boost controller and dialed it back up to 12.5 after removing the cat, you will notice a big power increase
Alan
2.216vturbo is offline
Old 12-06-2007, 08:56 AM   #6
Brad is this a silver and blue shelby charger by any chance it might be my old car? but I only had a 3" downpipe with high flow cat exiting before drivers rear tire. I am trying to track it down let me know
taco502001 is offline
Personal Loans | Loan | Facebook Proxy | Debt | Car Insurance
Page generated in 0.48254 seconds with 13 queries
