Old 12-18-2007, 02:24 AM   #1
Garrett turbo bolt torque
My Ride: '88 Daytona Shelby-Z
Engine: 138 C.I. Turbo 2
I pulled apart my turbo to clean it up only to find that I can't find the torque specs in my FSM. So does anyone know what I should torque the 8mm compressor housing, swing valve, and center housing bolts to? It's an '88 T2Daytona with an '89 2.5" swing valve.
enforcerdaytona is offline
Old 12-18-2007, 11:53 AM   #2
Re: Garrett turbo bolt torque
My Ride: 87 GLHS
Just look it up by fastener size somwhere. Regular bolt torque specs are just the max for the particular fastener. Some more precision parts on engines, etc are not necessarily based on the fastener yeild (check to be safe) though so only use this as a rule when it is to bolt things together.
M8 bolts in less than 12.9 should probably be 15-20 ft*lbs.
Look here:
Metric Steel Bolt Torques - Engineer's Handbook
-Rich
rfb6435 is offline
Mortgage Calculator | Web Advertising | Photoshop Tutorials | Money | Personal Finance
Page generated in 0.83084 seconds with 13 queries
