besides the ones previously Mentioned
also check out
turbominivan.com
minimopar.net
most the info they have is from Gus's thedodgegarage site but still good reading.
thedodgegarage is like a TD bible
after you done reading all you can, go check out the vendors that deal in TD's
3barracing.com
forwardmotioninc.com
fwdperformance.com
and there's more listed under vendors in the forum
and pretend you have unlimited funds and select all the best of the best products then sit there and wish you could actually "proceed to checkout".
I know I can't be the only one that has done that?¿? lol
ya starting with a "grainger" or boost bleed is where you'd start.
then you Intercool and Up the boost a little more.
then you really start having the fun. bigger turbo, alcohol/methanol injection, extra injectors ect. ect.. ect.. all in the name of more boost
then you blow a piston, have to rebuild and toss in a few performance mods along the way ported head, manifolds, removing balance shafts.
have fun with your New TD, just be carefull and run the good gas. it's more expensive but still cheaper than buying a new set of pistons.
