Old 01-02-2008, 09:52 PM   #1
grainger in the cockpit
My Ride: 89 lebaron turbo
Can I run my g valve inside the cabin? Or will there be ill affects?
pyro719 is offline
Old 01-02-2008, 09:58 PM   #2
Re: grainger in the cockpit
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
probably more boost creep, normally as close as you can get it the better(but for a ball spring type it may not matter as much?)
speeduphoria is offline
Old 01-02-2008, 10:03 PM   #3
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
I would say don't do it. It will not be consistant and the boost reference would be laggy.
Look for something I am working on real soon to adjust from the cabin for under $20...
The Winston valve™ aka W-valve™! Have most of the parts, just gotta assemble and test. I suspect it will be a couple weeks.
dyno sheet
fmic install:
crazymadbastard is online now
Credit Cards | eHarmony | Kelly blue book | Personal Loans | Free Credit Reports
Page generated in 0.28597 seconds with 13 queries
