01-26-2008, 05:02 PM
#21
Re: Water to air intercooler on my Caravan today!
My Ride: Neons + Caravan
Engine: 2.5T
The pump is from ebay, its for a Ford Cobra/Lightning. For the wire connector, I found the bosch style fuel injector plugs (found on an extra neon harness I had) works perfectly.
I will run it most of the time (actually, I dont have it on a switch yet, just running with ignition key on), but want the option to turn it off for say things like road trips to keep excessive wear on the pump down.
The setup right now is off a good relay and is running no problem! Just took it on a few hours of driving, not a problem!
OH, and yeah, I did 1" spacing between the radiator and the 2 heat exchangers. Actually the top one is using 2" spacers, and the bottom one is 2" spacers. Have the rad fan on a switch for a good hot summers day, too!
