Old 01-11-2008, 12:20 AM   #1
Water to air intercooler on my Caravan today!
My Ride: Neons + Caravan
Engine: 2.5T
Well, after much thought on how I wanted to intercool my beast, yet keep my AC system and still have the capability of high boost later down the line... I ended up this route...
I dont have the water going through it yet... I have he heat exchangers, I just need the pump, wiring, hose, a few T's and Y's and Im ready to go (within $150 now). Just thought i'd show it off.
NoDestiny is offline
Old 01-11-2008, 02:47 AM   #2
Re: Water to air intercooler on my Caravan today!
My Ride: -
Engine: -
Images: 28
should add some TEC cooling onto that beast =)
Paradox is offline
Old 01-11-2008, 01:01 PM   #3
Engine: 2.5T
MAN have I thought of that... I thought of it lots. But then I realized how much more money I would have to put into it and how my tiny battery is already gonna have a hard time with all this.
Its not completely out of the question... but for now, just simple water to air.
(Love my drink cooler / warmer I made though! Might post pics of that later )
Old 01-11-2008, 04:30 PM   #4
My Ride: -
Engine: -
Images: 28
Looks good though tell me how your temps are, I'm going to intercool my shadow and was thinking of running the charge hose into the same location the cold side of the IC is and run it ontop the ICto the other side.
Paradox is offline
Old 01-12-2008, 08:28 AM   #5
Looks good. Where did you put your battery?
Edward Kelly
Kelly-Mulhern Performance
www.kmperformance.com
c2xejk is offline
Old 01-12-2008, 10:28 AM   #6
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
that looks right at home there. Have you looked at siliconeintakes.com? they added some water air stuff.
dyno sheet
fmic install:
crazymadbastard is offline
Old 01-12-2008, 05:56 PM   #7
Engine: 2.5T
http://www.turbododge.com/forums/f4/...tery-pass.html
Old 01-12-2008, 10:37 PM   #8
My Ride: 85 GLHT, 87 ShelbyZ
I've probably asked before but what part of Idaho? Also what is TEC cooling? A buddy is putting that I/C on his GLHS and plans to put one on his Minivan also. He's gonna run a honda rad where the a/c condensor is I think for the heat exchanger as he found an aluminum one brand new cheap somewhere.
GLHNSLHT2 is offline
Old 01-12-2008, 10:55 PM   #9
Engine: 2.5T
Idaho = Payette, right next to Ontario Oregon and an hour away from Boise.
TEC = thermal electric cooling... you use Peltiers (which is an "electronic air conditioner" that absorbs heat from one side and dumps it on another basically) to chill one side, the heat is dumped on the other and you must keep it VERY cool in order to make it work right. My setup with simple aluminum heatsink and a few fans can make ice form on the cold side in a very short time.
For heat exchangers, Im using 2 tranny coolers, full size, stacked together in front of the radiator instead of a full radiator. Should cool the water plenty well and not add TOO much weight... and was only $80 all together.
Old 01-13-2008, 02:53 AM   #10
My Ride: 91 shadow convert.
Engine: 2.5t
Images: 14
Please.! I have to see a picture of this setup.
COASTAL SHADOW is offline
Old 01-13-2008, 12:01 PM   #11
Engine: 2.5T
??? I posted some pics in the first page. Ill be posting more pics as I get teh parts in and start installing!
Old 01-13-2008, 01:41 PM   #12
boosting change
The Pope's Avatar
doing the same thin on my van. I am standing the IC upright next to the head and running the air cleaner pipe around the IC. Then I am using a Walmart 500 LPH boat bildge pump instead of the lame Ford unit that cost 5 times more and flows less than half. As far as a heat exchanger a welded aluminum performance Honda Civic engine rad fits in front of the van engine rad. Use the fan bolt holes to mount it and run your hoses. The engine rad is cheap on Ebay, $60?
The Pope is offline
Old 01-13-2008, 06:42 PM   #13
Engine: 2.5T
DOH! Nobody told me wal-mart had a pump! Ah well...
Hmmm, have to show me some pics of your van once you get it going!
Old 01-13-2008, 09:07 PM   #14
Engine: 2.5t
Images: 14
Sory I meant pics of the tec setup/
Old 01-14-2008, 05:33 PM   #15
My Ride: -
Engine: -
Images: 28
here is a image of a small one
Paradox is offline
Debt Consolidation | Credit Cards | Debt Consolidation | Car Loan | Free Ringtones
Page generated in 0.51794 seconds with 13 queries
