Old 01-17-2008, 11:12 AM   #1
No boost
My Ride: 86 GLH-T/92 Typhoon
Engine: 2.2L/4.3L AWD turbo
Ok, so I helped a friend put in a T2/T3 clutch in his '89 T1 2.5 Acclaim this last weekend. Removal/install went well. Car drove find for a few days (boosting normal), but now the car will not make boost in lower gears, and occasionally makes <2 PSI in higher gears. This car is 100% stock excluding a cone filter (because the stock box had a crack in it). All of the vacuum lines are good, and so is the turbo to throttle body tube. I'm thinking his turbo might be seized, but it's kinda weird that this happened shortly after the tranny was out
Thoughts?
glhman is offline
Old 01-17-2008, 11:42 AM   #2
Re: No boost
Turbo-Baron's Avatar
My Ride: 89 lebaron /shadow
Engine: 2.5 turbo
Images: 20
Check if the Waste gate rod has popped out of the Swing valve.
Turbo-Baron is offline
Old 01-17-2008, 01:21 PM   #3
Re: No boost
My Ride: 85 laser
Feedback: (8)
Yea I swear working with cars strange things seem to happen all the time, just the other day my buddy called me over cause his tranny line blew out and he lost all his fluid and then the car wouldnt start when we got the lines fixed so it appears that the ignition module went at the same time that trans line did, just a strange coincidence I guess.
Check to see how the wheel spins if somethings wrong it will probobly be stiff or the blades will be hitting the sides of the compressor.
jim34 is offline
Old 01-17-2008, 04:07 PM   #4
Re: No boost
My Ride: 91 Shadow turbo vert
how tight is the hose coming right off the turbo...mine comes off all the time...but my turbos SPEWING alot of oil lol.
amiturbo is offline
Old 01-20-2008, 10:09 AM   #5
Re: No boost
I've checked the connections and they are good. I've blown an intercooler hose on my Omni before, and I know what it sounds like afterwards. His doesn't even sound like the turbo is spooling like it should. I'll have to check the WG rod
glhman is offline
Old 01-25-2008, 04:49 PM   #6
Re: No boost
My Ride: 1989 Dodge Daytona
see if the turbo spins
and check the engine codes....
could be a map sensor or vacuum lines of such
daltondaytona is offline
Advertising | Car Loan | Bankruptcy | Santa Cruz Hotels | Best Credit Card Deals
Page generated in 0.35756 seconds with 13 queries
