01-24-2008, 04:27 AM
Re: fuel to boost ratio
My Ride: 1986 GLHS #126
Engine: stock
exactly.
what you can to do is run a fuel pressure gauge off your fuel rail and mount that gauge where it can be seen while driving, for example you can duct tape it temporarily to the outside of the windshield...then take it out for a test drive and make sure your fuel pressure goes up 1 psi for every 1 psi of boost.
for optimum tuning , power, and reliability you also should verify the air/fuel mixture at maximum boost, 11.0-12.5 is a good range at full throttle.
