Old 02-17-2008, 05:21 PM   #1
help with wastegate install
just got a new factory style adjustable wastgate in and need to know how to set it up for proper operation. thanx. justin.
cybillized is offline
Old 02-17-2008, 05:24 PM   #2
Re: help with wastegate install
MEOW!
My Ride: 87shelby charger
Engine: 2.2L TII
Images: 148
you can take the one on your car and messur it and make the other the same or alittle shorter(note. shorter will make it have MORE boost)
turbomini is offline
Old 02-17-2008, 05:26 PM   #3
My Ride: 85 GLH
Engine: 2.5CB
by setting it you mean adjusting the threaded rod. you can set it how ever you want to.
shortening the rod will make the spring tension strong raising the boost, lengthening the rod will make it weaker lowering the boost.
this is how i have mine at the moment, with no vaccuum line to it.
just an example--if you set it at 18 (no vac line) and try to run a manual boost controller 18 is the max, you can adjust lower from there. or 26 or what ever.
then again i dont know what kind of spikeing issues and boost creep a guy will have without a line, i haven't got to test much on my glh, but this week i will.
the man gus ran stuff this way so its not a bad idea
ZachT is offline
Old 02-17-2008, 07:00 PM   #4
L_P
My Ride: 95 Dodge Stealth TT
Engine: 6G72 3L
If my memory serves me the correct setting is just closed and then an additional half or full turn... But as the above post states you can set them for a higher base pressure.
-John
L_P is offline
Old 02-18-2008, 07:35 AM   #5
My Ride: '89 Daytona Shelby
gus's
Like Zach said and ...Check out Gus' page on this ... and other "old school" goodies for the TD.
puppet is offline
Old 02-18-2008, 05:30 PM   #6
thanx for the information everyone.
Compare | Web Browsers & FTP Clients | Loan | Mortgage Calculator | Cheap LCD TV
Page generated in 0.95042 seconds with 13 queries
