Old 02-20-2008, 08:14 PM   #1
Holset+2.4Head+LBody
My Ride: 82 Rampage
Engine: 2.4 16V turbo. NGC M
Here are some pics of my holset into an L Body install
Holset+2.4Head+LBody - Ontario SDAC
Dean Stillie is offline
Old 02-20-2008, 09:33 PM   #2
Talking Re: Holset+2.4Head+LBody
My Ride: 84 Plymouth Turismo
Engine: 89 2.5 I/C TURBO
going for 10's again? awesome stuff Dean......
Robb
The "MO": 84 Plymouth Turismo..:: 89 - 2.5 CB Intercooled Turbo/as of Jan 22/08 - London, Ontario
TurboTurismo is offline
Old 02-21-2008, 08:41 AM   #3
Shadow's Avatar
1/4: 11.090
Images: 6
Lookin good! What size hybrid is the Holset replacing?
11.53 & 123.6mph MB's fastest SRT-4
Shadow is offline
Old 02-21-2008, 10:23 AM   #4
My Ride: your mother
Feedback: (6)
I think it was a 57 trim SIII....but dean can confirm this b4 me!
Juggy is offline
Old 02-22-2008, 07:15 PM   #5
My Ride: 82 Rampage
After the old Flange is cut off.
New flange ready to weld on.
turbo comparison
Old 02-22-2008, 07:16 PM   #6
My Ride: 82 Rampage
Some more pics....gettin there!
Old 02-24-2008, 10:24 AM   #7
The Pope's Avatar
The instructions anyway say to have the wideband at 900 or less EGT or with a heat sink or move it a couple ft down stream from the turbo. Are you worried about damaging the wideband? It looks like a 12cm housing, which one is that? Did you run the 9cm HY or the 12cm? May have said it and I missed it. I like to remove the silencer from the compressor too to make it more noisy. Really sweet, I wish I had more time for my Rampage. I have been watching your threads close, planning A 2.4 or hybrid with my Mex manifold and new 04 Holset. Sorry for so many questions but I don't want my wideband under my car and some have said the 9cm I have is too small.
I'm seen a lot of posts on your engines over time. Any posts on the Rampage? Suspension setup and so on. What axles are your running now? I know its popular to see the power but I want to see more on how your using it I always make power and then shread my car
The Pope is offline
Old 02-24-2008, 11:58 AM   #8
My Ride: 82 Rampage
I've had egts on my cars before and after the turbo. I found that the 16v head the egt's are cooler then an 8v My car goes dead lean hesitating at about 1400 degrees @ one inch from the port..I'm sure it will be a little cooler after the turbo. I've only had the wide band in there for about 50 runs been ok so far.
Well the reason the k frame is out in the pics is I just put in a Garry Peloquin diff. I run stock suspension with MP front springs. No sway bar and air shocks in the back. The rear leaf springs are now mono leaf, defineately softer then before in the back. But its a weight vs stiffness thing. The biggest consistency change was switchin from 22" tall slicks on 15" wheels to slicks with some sidewall.24.5x13" now... both are/were 8" wide.
I've been using stock axles but have had some issues with them. The rebuilders now have new inner and outer joints on them the inner is bigger then a stock L was so I hope it is stronger too.
Old 02-24-2008, 09:00 PM   #9
My Ride: 82 Rampage
After installing the k frame, Lower Holset support bracket, and main exhaust pipe.
Old 03-02-2008, 06:40 PM   #10
My Ride: 86 GLHT
HHHOOOOTTTT SEX!!!! thats what i think that is nice work
GLHTroy is offline
Old 04-01-2008, 09:00 PM   #11
My Ride: 82 Rampage
Found this nice tight L bow 4" diameter intake hose for my holset....have a couple more here somewhere if anyone wants one lmk.
almost life size!
Old 04-11-2008, 06:32 PM   #12
My Ride: 82 Rampage
Well its up and running this baby spools like a stocker!!
Old 04-11-2008, 10:17 PM   #13
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
Hey nice work Dean, I may need an L bow like that if I ever step up to a different compressor cover.
speeduphoria is offline
Old 04-12-2008, 01:04 AM   #14
The Pope's Avatar
I bet it hits a lot harder than a stocker though when will you get track opinions?
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
70 R/T SE Challenger
The Pope is offline
Loans | Upvc Doors | Free Insurance Quotes | Free Advertising | Credit Cards
