Old 05-02-2008, 04:45 PM   #46
Re: New S60 turbo CRAZY lag, normal? Break in?!?
My Ride: Neons + Caravan
Engine: 2.5T
Sweet. New parts!
After installing, definitely feels "smoother" and idles much better! Can't wait to get some time to turn up the boost
NoDestiny is online now
Old 05-02-2008, 07:35 PM   #47
My Ride: 85 GLHT, 87 ShelbyZ
what's the idle a/f's at?
GLHNSLHT2 is offline
Old 05-02-2008, 10:25 PM   #48
Engine: 2.5T
No idea at... My laptop's HDD is done for
Old 05-14-2008, 07:59 AM   #49
My Ride: 89 Daytona Shelby
1/4: 12.400
Originally Posted by NoDestiny View Post
Yeah, I was thinking of ditching the boost controller to see what it does (though, it is a brand new TurboXS high performance version), but just to see what the boost does.
What could cause my wastegate to stick though? When I installed it, I adjusted the arm so I had to pull just slightly on the arm to close the wastegate properly, to make sure there was good tension on it.
No,
Be sure that you have the bleed set on your turboXS HPMBC. Run it in all the way down and then out 3 turns and see if this doesn't improve the spool. Thats what it is intended to do on laggier turbos.
FYI,
Marion
mario03SRT is offline
Old 05-14-2008, 08:08 AM   #50
1/4: 12.400
No,
I share your disappointment on your situation. I have a E2 46 trim from FM. To get mine to spool decent I did this. I have all the goodies so my flow is pretty good for a 8v. When the turbo hits it's great.
- Adjusted my Taft 2 cam 4 degrees advanced.
- Lowered my FP to 38-40 psi (w/o vacuum) AFR is now in the 12's till
about 2800/3000 and still goes low 10's at 6200.
- Advanced my timing to 14 degrees.
FYI,
Marion
Old 05-14-2008, 09:06 AM   #51
Engine: 2.5T
Good advice, thanx!
Im getting the last of my goodies in order and I should be able to tune this puppy up properly. It starts to spool (from a complete stop, no brake-torquing) around 3K and hits full spool by 4K, but I still need to put the air charge sensor in, work on my AFR, and a few other things.
But yes, I have my boost controller set up like that, as per the instructions that came with it. Didn't realize what it was for exactly, book just says, "fine tune".
Ill have to get an adjustable cam gear soon, among other goodies
Thanx again!
Old 05-14-2008, 09:08 AM   #52
Engine: 2.5T
Dang I cant find the edit button to simply add in...
I am running 14* base timing as well, BTW! Also, adjustable regulator and walbro pump came in So I should be able to adjust my base pressure shortly.
Anybody know if an SAFC is a handy gadget on these motors? Love to be able to lean out down low and wet it more on the top end!
Old 05-14-2008, 09:23 AM   #53
1/4: 12.400
Yes they work on these cars. I'm doing either one of those or a Mega Squirt in the future.
Credit Cards | Loans | Mobile Phone | Mobile Phones | Loans
Page generated in 0.28945 seconds with 12 queries
