Old 04-22-2008, 01:02 PM   #1
How much HP can I get out of my setup?
My Ride: 88' Dodge Daytona
Engine: Common block 2.6L?
I was wondering what WHP numbers can I see from my set-up. I want 350WHP or more.....This my set up:
*VentedCB with stock 2.5 crank
*JE .040"over pistons
*Eagle Rods
*Clevite Race Bearings (rods and mains)
*ARP Main studs
*Stock head
*High volume oil pump
*Copper sprayed cometic head gasket
*Turbonetics T3/T4 50trim T04e with .48A/R exhaust housing
*Supra Intercooler (front mounted)
*2.5" intercooler piping
*stock throttle body :-(
*stock one piece intake manifold
*3"swing valve
*2.5" down pipe with 3" exhaust after that (no CAT or muffler
*AFPR
*52lb/hr injectors
*Stage 5 CAL from FWDP
*3-Bar MAP sensor
*255 Walboro fuel pump
I'm probably leaving something out, but this is my set-up for the most part and it runs damn good. Just wanna know what WHP I should be expecting. I plan on running 24-26psi at the track/dyno.....Honost opinions on HP levels Thanks ALOT,
Lorenzo
Turbo_zo is offline
Old 04-22-2008, 01:37 PM   #2
Re: How much HP can I get out of my setup?
Feedback: (32)
You probably won't get more than 270hp with that .48 turbine housing.
tryingbe is offline
Old 04-22-2008, 02:04 PM   #3
really??? even at like 25psi?........so I should upgrade to a .63a/r housing? If with that what am I looking at then?
Turbo_zo is offline
Advertising | Credit Cards | Mobile Phone | Edinburgh Hotel | Mortgage Loans
Page generated in 0.31800 seconds with 13 queries
