Old 04-07-2003, 07:40 PM   #1
T2 Waste Gate Can
T2 Waste Gate Can vac line unhooked
should be able to hit 20 psi boost right, if no leaks at ic hoses and no vac leaks, and the bov doesnt leak....
DaytonaConnection is offline
Old 04-07-2003, 08:45 PM   #2
zman
Will hit cutout at 14.7. Make sure you have enuf fuel to support 20 psi before you try it or have an extra motor ready to drop in, pistons only take a few seconds to turn into ashtrays.
Old 04-07-2003, 09:27 PM   #3
yes i do have a cutout riser, i just came back from a run with the can unpluged. in 4 gear at wot 4000rpms it spiked to 18psi setteled to 16 maybe the can spring is weak, but if it were weak wouldnt it continue to fall off boost?
Old 04-07-2003, 09:41 PM   #4
zman
what year of can is it??
Old 04-07-2003, 09:49 PM   #5
no the spring is not week thats normal you need to place a couple of thick washers behind the waste-gate can bolts.
artur_p is offline
Old 04-07-2003, 10:00 PM   #6
the car is a 88 shelbyz but i moded a wastegate can witch was bigger for a 89 turbo t1 dont know if it makes a differance it was a mitsu unit...
Old 04-07-2003, 10:14 PM   #7
zman
dont bleieve that the mitsu cans can hold to much back. the 89 garrett cans are tougher. try shimming the can an see what happens.
Old 04-07-2003, 11:03 PM   #8
about how thick of shims, if that works with enough fuel whats good boost to run with a stock ic, also iam useing +20s and a afpr set to a base pressure of 37psi
Remortgages | Remortgages | Free Credit Report | Mortgage | Xbox Mod Chip
Page generated in 0.30719 seconds with 13 queries
