Old 05-09-2008, 03:38 PM   #1
Bov
My Ride: Lebaron
What are the advantages/ disadvantages in installing a bov?
How do you do it?
thanks
Minor Threat is online now
Old 05-09-2008, 03:42 PM   #2
Re: Bov
My Ride: Lebaron
Oh yea, one more... do i need a bov to instal a g valve
Old 05-09-2008, 03:54 PM   #3
Re: Bov
My Ride: TIII R/T
Engine: 2.2L TURBO III
Gvalve is totally separate from the BOV, g valve is to manually up your boost. BOV is the vent pressure once the Throttle body closes to turbine prevent surge
xtrempickup is offline
Old 05-09-2008, 04:19 PM   #4
Re: Bov
My Ride: Lebaron
Will it help anything on a stock setup? or will it help after i install g valve
Old 05-09-2008, 04:50 PM   #5
Re: Bov
My Ride: Neons + Caravan
Engine: 2.5T
Depends on your setup. Seems that most turbo dodges come with some type of blow off valve stock. It can help if the BOV isnt working properly (either isn't sealing completely or is not opening properly).
The G-Valve, if done properly, will help by raising your boost.
NoDestiny is offline
Old 05-09-2008, 05:28 PM   #6
Re: Bov
My Ride: Chrysler Daytona C/S
Engine: 2.5L
Images: 1
bov protects your turbo from getting damaged. If u have 88 older pull-through setup you don't need a bov but if its 88 up blow-through intake then yes you should have bov. G valve doese nothing to do with bov if you have either of them they would still function the same. G valve you can choose how much boost you want manually
venom800tt is offline
Flights | Free eBooks Download | PHP Photo Gallery | Online Loans | Myspace Backgrounds
Page generated in 0.31878 seconds with 12 queries
