Old 04-08-2003, 05:10 PM   #1
3 bar map sensor
LILVIPER
whats the advantage of going to the 3 bar sensor over the stock one
Old 04-08-2003, 06:44 PM   #2
My Ride: 1987 Shelby GLHS 189
It's almost that simple.... You would need a computer recalibrated for the 3-bar map as well.
The advantage is You can run boost up to 29 psi and the calibrration will compensate for it. No need for a rising rate reg and adj FPR (good to have one anyway).
If you are not looking to run big boost (more than 20 psi...) I wouldn't do it
glhsken is offline
Old 04-09-2003, 12:04 AM   #3
RABBLEROUSER
do you need bigger injectors?
Old 04-09-2003, 12:22 AM   #4
zman
you would need whatever injectors the calibration is for.
Old 04-09-2003, 07:06 AM   #5
My Ride: Reliant
Engine: SOHC 2.5 8V
what comes first chicken or the egg?
A 3bar map sensor *allows* a stock computer to see over 14.7 psi, the reprogramming of the computer *allows* it to take advantage of the sensor.
From there you need extra fuel to support the higher boost levels and the stock injectors are pretty much maxed out.
gdonovan is offline
MPAA | Bankruptcy | Debt Consolidation | Advertising | Car salvage
Page generated in 0.45702 seconds with 13 queries
