Old 04-08-2003, 07:33 PM   #1
anyone have pics of Gvalving a T1 shadow?
90TurboShadow
topic pretty much says it all. i made a Gvalve. and i completely forget which Vacum lines to T this into. i cant find my previous post. and i completely forget. anyone do this or know how? or has pics? plz post them. thanks
Matt
Old 04-08-2003, 09:14 PM   #2
HP=(mph/234)^3*weight
Follow the vac. line from the wastegate. It should connect to a solenoid on the pass. side.
The other side of the solenoid should have a vac line going to the manifold or other vac/boost source.
You can disconnect both lines from the solenoid and connect them to the g-valve. Put the side with the small hole closest to the wastegate.
This will work, but for best results, you should make the lines as short as possible.
Old 04-08-2003, 09:21 PM   #3
90TurboShadow
k i used JT's set up to make a G valve. so there are 2 ends. the ball end of the valve would that go to the intake? and the other to the waste gate???
Old 04-08-2003, 11:22 PM   #4
Robert McFee
Heres a pic of my old set up on my 87 SC,not very good but it shows where everything is.
Old 04-09-2003, 03:45 PM   #5
90TurboShadow
i dont understand that pic. i cant make out the Vacum lines. nice shinny gvalve tho lol. im gonna go out and take a look. see if i can find the vacum lines u guys are talkign about.
Old 04-09-2003, 09:15 PM   #6
90TurboShadow
ttt
Old 04-10-2003, 01:00 AM   #7
My Ride: '86 CHarger Shelby
you're correct.. the end with the ball goes towards the pressure source.
Vanquizor is offline
Old 04-10-2003, 06:47 AM   #8
90TurboShadow
alright thanks. would a small ball bearing outta a bicycle hub work fine for this valve?
Cadillac | Art Instruction | Remortgages | Wealth & Finance News | Advertising
Page generated in 0.30161 seconds with 14 queries
