05-17-2008, 12:30 PM
Re: G valve installation
My Ride: 86 Laser XT
Engine: 2.2 turbo
When you do the instalation you need to be cautious. Only a slight turn at a time which is about 1 lb. This will ensure you stay around the 10 lbs. rather than going up higher than that and causing you to melt a piston. 10lb's of unintercooled boost is fine. 12+ you are pushing your luck. Remember when you up the boost you prolly should run higher octane gas to keep from detonation.
