Old 04-28-2003, 12:56 AM   #16
r3mix
Originally posted by unclejemima
1) port out the wastegate passage
2) go to a more restrictive exhaust
3) upgrade your turbo to one with a better passage
4) install a proper external wastegate
how would you go about porting out the wastegate passage? i have a 1991 daytona shelby, and only recently has boost creep been a problem. I figure if i get a brand new TEO4H with and brand new wastegate, i should be back to holding 12psi. Is it worth trying or should i just get a differnt type of turbo altoether like a super 60 or t3/t4 hybrid? I just want to elimitate the **** boost creep, its sooooooooo agrivating!!!
thanks guys
I'm running a new TEO4H and wastegate and it creeps in the higher gears. I'm just going to install a 5th injector and run this mitsu as hard as it will go. Then it wont creep anymore
Old 04-28-2003, 09:11 PM   #17
would adding +20% injectors help?
unclejemima is offline
Old 04-29-2003, 06:20 AM   #18
My Ride: 89 Caravan SE turbo
Engine: 2.5L SOHC
Only if you need more fuel. Remember: boost creep has nothing to do with your fuel setup--it's an exhaust energy problem. You can add a dozen cold start injectors and up your fuel pressure to 200 psi... but your boost is still gonna creep until you fix the actual problem.
(Disclaimer: the above fuel system "suggestions" were highly sarcastic and not meant to be taken literally.)
TurboMinivan is offline
Old 04-29-2003, 10:39 PM   #19
r3mix
I'm saying, in my case, I'm going to max the mitsu out so it can't go any higher. Therefore, no boost creep.
Bad Credit Mortgages | Mobile Phone | Loans | Car Insurance | DVD Sale
Page generated in 0.91853 seconds with 13 queries
