07-06-2008, 05:47 PM
Re: making grainger valve go to 30psi
Politically Incorrect
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
no, 2 of them in series will not double up on the pressure, it will just get by the first and the second will see the same press as the first saw.
Find an old-school hardware store, not a home depot, but a true value or an ace. they should have bins with all kinds of little springs to choose from. find a couple with the same dimensions as the one you have and different firmness and go home and play....
or, you could go a whole different route.
get a solenoid valve that will hold the 30 psi and wire it into an adjustable pressure switch. I know you can get all that online and the press switches are easily adjustable (up to any press you can imagine) and since its electric(no messing around with a hot g-valve), once the switch sees the preset press, bam! and the solenoid opens
