08-03-2008, 10:38 PM
Re: Car hits 8 psi and breaks up
My Ride: 87 Shelby csx
Engine: 2.2 turbo
my car did the same thing, after much stress and pain in the ass, i found two problems, one being cam timing mine was one tooth off and did the same thing, reset timing belt and fixed the problem, other time i saw it was in the drive shaft for the oil pump being off a tooth, making timing permenantly off.
08-05-2008, 04:06 AM
My Ride: 86 SC, 94 Duster
Engine: 2.2 TI, 3.0L
A grainger valve doesn't go between the solenoid & wastegate, it is used instead of the solenoid.
Check out these pages, they'll probably answer all your questions & more:
Donovan's Dodge Garage
MiniMopar Resources
www.DempseyBowling.com
Gus Mahon Homepage
Welcome to the board!
09-08-2008, 08:08 PM
My Ride: '89 Daytona Shelby
Your exhaust flow ... or lack of it is causing the creep.
What do you know about the engine and mod's done under the hood as it stands? Post what you know you have ... ECU, injectors, the whole nine. We can help then.
09-20-2008, 11:40 PM
My Ride: 1986 Daytona Turbo Z
It is like the other guy said, the grainger valve does not go in between the solenoid and the wg... this is probably what you did. You are hitting the boost cut(which is bad)....You have to block off the vacuum line from the solenoid and add another vacuum line going from the intake to the g-valve to the wg. If you have the g-valve between the solenoid and the wg, no matter how it is adjusted, it will always overboost. I had the same trouble with my car and after a month of asking, no one was able to answer that question for me. Best of luck to you and I hope that helped
10-11-2008, 10:21 AM
My Ride: 89 omni & 90 T1 shad
Engine: 2.5L HX-35 w/alcohol
^i would checks the timing as suggested by this guy, then i would check the MAP sensor to be sure it dosnt have a crack or somthing in the vac/boost hose going to it (that would send a wack signal to the computer), then i would put in a new coil... this seems too simple, but in my opinion its most likely the cause (they just get old and i bet its still the origonal one right?),
then id go over the vacuum lines and make sure there all attached and propper, then id put in new plugs with about a .025 gap. my car has done this before,and did it again not long ago. a new coil fixed it once, and smaller gapped plugs fixed it last time, and making sure the timing is right will usualy surprise you... cause its often not, especialy with a "new to you" car.
good luck.
oh, and as for wondering what kind of boost these motors can handle, with the right stuff so it dosnt blow up, ive heard of guys running 38psi before. i run 30psi+ with no problems... but lots of good parts, time, and experiance is what keeps it together.
