Old 04-26-2003, 04:26 PM   #1
t3/t4 @ 13psi or TEO4H @ 17psi
i want to put a T3/T4 turbo on my 1991 daytona shelby 2.5 TI, but i am being told it will be an SOB to change all the lines for a new turbo and be expensive. I am putting fordged pistons in as well, mabey i will just get a brand new TEO4H, and boost it too 17psi or so. I only want a high 13, low 14 car so i would only boost the t3/t4 to 12psi or 13psi. Can i get close to the same power by boosting the snot out of a new TEO4H, because hooking it up will be soooo much easier. I would also get +20% injectors, and a ajustable fuel regulator and 2 TII I/C's. Anything else i need, a new fuel pump mabey?
thanks!
unclejemima is offline
Old 04-26-2003, 07:08 PM   #2
My Ride: 1989 Shelby CSX
Engine: 2.2 16v Hybrid
you'd be better off putting on a stock tII turbo on your car...then all you'd have to do is replace the turbo lines and it would support a low 14 high 13 second car.
--Scott
scott is offline
Old 04-26-2003, 07:24 PM   #3
My Ride: 1987 Shelby GLHS 189
greed.. A stock TII unit is more than enough for that.
glhsken is offline
Old 04-26-2003, 08:35 PM   #4
so just use a stock TII turbo? Thats a garret, right? What model its it? Any idea where i could get the oil lines from? How hard is it to change the lines?
thanks!
Old 04-27-2003, 02:50 PM   #5
My Ride: 88 Lancer Shelby
Engine: 4cyl. 2.5L
The garrett lines go in the same place as the stock Mitsu lines. I think lines from an 87 and earlier T1 car(they have older style garrett T03's) will work. You'll need coolant supply and return, and a oil feed. The oil return is the same I believe.
LancerShelby is offline
Debt Consolidation | Pink Ranger | Debt Consolidation | Debt Consolidation | Debt Consolidation
Page generated in 0.93360 seconds with 13 queries
