Old 04-27-2003, 07:50 PM   #1
G-Valve questions...
My Ride: Titan & '89 C/S AGS
Engine: 2.5L T1
To those guys running g-valves: When you run a g-valve, do you get max boost even at lower RPM? For example, if your g-valve is set to 12psi, and you floor it, you get 12psi even at, say, 2K rpm? The reason I ask is that I know the computer (stock) limits the boost at lower rpm to say 7-8 psi, then allows full boost above about 3K. If the g-valve allows full boost at all RPM, what does that do to the durability/longevity of the engine? Just curious before I turn up the wick...
-Rob
Shel-Game is offline
Old 04-27-2003, 09:33 PM   #2
johnr7
Mine is set to 12 psi, and it pops up there way quicker than when the computer was controlling it.
I don't know the exact RPMs, it still takes a little bit for it to spool up, but that boost needle shoots to twelve pretty fast.
Can't speak about longevity, but you'll like the acceleration!
- John
Old 04-27-2003, 09:41 PM   #3
Yes it does hit full boost sooner, but not at 2k rpm. The actual valve itself doesn't do anything for durability/longevity. How much you decide to turn it however may have an effect w/o the proper fuel to go with it.
89daytonaTII is offline
Old 04-28-2003, 08:28 AM   #4
Engine: 2.5L T1
The reason I was asking is that I modified my own cal and, well, it scared me a little. Stock, the boost vs. rpm table gives 6 psi up to about 2500 rpm, then ramps up to 11 psi by 3500rpm and stays there until about 6K. I changed it to be 9 psi from idle to about 2500, then ramp up to 14psi by 3500.
Then I took it for a test drive; even with a little throttle, the boost needle shoots up to 9psi and the car really pulls hard (I actually blew the bypass hose off, need to get a clamp on that thing)! Anyway, I was a little concerned that maybe I'd gone too far. Sounds like I may be able to do more...
-Rob
Old 04-28-2003, 11:24 AM   #5
My Ride: '04 SRT-4, '87 CSX
Engine: 2.4L I4
I think the only reason for ramping it up was to reduce the stress on the transmission. It's lots more fun with a G-valve.
CSX321 is offline
Myspace Layouts | Vegas Hotel | Remortgaging | Free Advertising | Magazine Subscription
Page generated in 0.26753 seconds with 13 queries
