Old 08-29-2008, 10:57 AM   #1
smoke from the exhaust
Mitsu Booster
My Ride: 90 shelby
hey any one know what happens when the turbo goes ? i think that might be my problem 1990 daytona shelby 2.5 turbo heavy smoke came out on the highway at 65mph got off the road and found all coolant gone pulled the head gasket off and it looks fine no coolant on the plugs or in the oil can the turbo go like that?any help would be great
90 shelby is offline
Old 08-29-2008, 11:20 AM   #2
Re: smoke from the exhaust
My Ride: 89 Daytona
Engine: 2.2 T2
Feedback: (6)
yep, it sounds like the turbo is gone. do you have access to your turbo, is it removed? If so, you should see the oil/coolant in the swing valve, exhaust side, and/or intake side. You will also see it in the down pipe.
89turbodude is offline
Old 08-29-2008, 11:28 AM   #3
Mitsu Booster
My Ride: 90 shelby
going to pull it off today i will check thanks
Old 08-29-2008, 11:30 AM   #4
Mitsu Booster
My Ride: 90 shelby
any one know where to get a turbo at a good price?
Old 08-29-2008, 12:31 PM   #5
My Ride: 85 laser
Feedback: (8)
never heard of a turbo going out like that usually they blow the oil seal
jim34 is offline
Old 08-29-2008, 01:43 PM   #6
My Ride: shelby z
+1, if it is a coolant issue i would not suspect the turbo
mmtphoto is offline
Old 08-29-2008, 02:22 PM   #7
Mitsu Booster
My Ride: 90 shelby
well it has coolant and oil that go to the turbo the oil lubes the bearing and the coolant cools it off so i guess it could happen But I am not sure this is why I am posting for any one to give info on this issue I am haveing
Old 08-29-2008, 03:28 PM   #8
My Ride: 85 laser
Feedback: (8)
The only way the turbo would leak water is if the housing just suddenly cracked while driving down the road witch is not likely, and it would probobly send water into the oil or just leak externally.
Can you post a pic of the headgasket ? Other than that we're just speculating it could be a cracked head, block, headgasket, warped head.
It would have been a good idea to pressure test it before you took it apart
jim34 is offline
Old 08-29-2008, 06:15 PM   #9
My Ride: shelby z
Have to say I agree with Jim34, I went through this about 5 years ago with my 88 daytona shelby, and mine ended up being the oil in the turbo-but when looking into the cause of the smoke, i was assured by numerous sources that it would be virtually impossible for it to be an internal leak of antifreeze in the turbo-JMO, but the headgasket and head/block should be checked out thoroughly before you come to the conclusion that it has anything to do with the turbo.
mmtphoto is offline
Old 08-29-2008, 07:53 PM   #10
My Ride: 89 Shadow
Engine: 2.5 turbo
+1 on it not being the turbo.
Moparbishi is offline
Old 09-02-2008, 09:12 AM   #11
Mitsu Booster
My Ride: 90 shelby
I want to thank you all for your input I did find out what happened it was the 3in rubber hose on the left side of the head that got a pin hole in it and sprayed the manifold which caused the smoke see what happens when you jump into things without checking it out first.... any way i wanted to do a head gasket and t-belt now is a good time I am looking for the intake hose from the t-body to the turbo any ideas where to get it it is not made by mopar any more any place you can think of ? any ideas for performance parts?????
Online Loans | Credit Card Debt Consolidation | Download movies | Free Ringtones | Bankruptcy
Page generated in 0.37070 seconds with 13 queries
