Old 04-30-2003, 12:08 PM   #1
Big Mitsu Turbo??
walsnart
Does/Can somebody run a big mitsu turbo like a 20G?? I ask because a local shop is clearing out their stock and has a few 20G's at a big discount.
If I use it on a Turbo 2 that originaly had a Garrett dun I just swap the manifold and use the 20G?? Thanks!!
Old 04-30-2003, 07:35 PM   #2
Hybrid Booster
The TII and the Mit turbos used the exact same manifold, the problem is the 20G probably uses a std Garrett flange and not hte Dodge offset pattern. Easy to overcome, but not a complete bolt in.
DOHCRT is offline
Old 04-30-2003, 08:49 PM   #3
walsnart
So what is needed to "overcome" the problem??
Anybody here with a bigger mitsu turbo??
Thanks!!
Old 04-30-2003, 10:58 PM   #4
joffficer
Does the '90 Talon use a larger mitsu than the one Dodge used? Would it make a good replacement.. any better?
Old 05-01-2003, 12:43 AM   #5
walsnart
I know the that DSMs (90-94) use the TD05H and that the autos used the TD04. DSMs form 95+ use a Garrett t25.
As for the upgrade aspect.... not really worth it in most cases.
ALSO....If any of you need to know what cars use what turbo, let me know because I know just about every one of them.
Loans | Debt Consolidation | Mortgages | Debt Consolidation | Debt Consolidation
Page generated in 0.34871 seconds with 13 queries
