Old 09-24-2008, 03:47 AM   #1
89 cast iron side of turbo with 2 1/2 opening
My Ride: 87 shelby
1/4: 14.060
89 cast iron side of turbo with 2 1/2 opening call 8137584181
sittinduck is offline
Old 09-24-2008, 08:04 AM   #2
Re: 89 cast iron side of turbo with 2 1/2 opening
My Ride: '89 2.5 Turbo Spirit
Engine: 2.5 Turbo
Yeah, right.
Tim_K is offline
Old 09-24-2008, 10:28 AM   #3
Question Re: 89 cast iron side of turbo with 2 1/2 opening
My Ride: 87 shelby
1/4: 14.060
Originally Posted by Tim_K View Post
Yeah, right.
don't undestand tha comment:
Old 09-24-2008, 11:49 AM   #4
1983Rampage's Avatar
My Ride: 1989 Daytona ES
Engine: 2.5l T2
Feedback: (10)
Are you looking for the swingvalve (the cast iron portion of the turbo that is bolted onto the turbo and has the O2 sensor in it) that has the opening going down for the 2 1/2" downpipe from an 89+ Dodge Daytona? If so, put an ad in the Parts Wanted section and you may find somebody willing to part with one. Or look for somebody parting out an 89+ T2 Garrett car that has the proper size swingvalve. I have ported 2.25" and a non-ported 2.5" swingvalves and I am not willing to part with either of them yet. Which I take it you are looking for a Garrett, not Mitsubishi turbo.
1983Rampage is offline
Old 09-24-2008, 12:53 PM   #5
My Ride: 87 shelby
1/4: 14.060
i have a BF/S dodge daytona and the 2003 nhra national record holder and i am told that the cast iron part of the turbo has a 2.5 opening as opposed to a 2.06 opening and its a bolt up and you cant tell the differance. that you can use the opening for about a 15 hp gain. cat now runs CF/S and runs 14.02 and i know it will do more but i am learning about turbos
Old 09-25-2008, 02:50 PM   #6
Engine: 2.5 Turbo
You don't even use the proper terminology, you've only got 10 posts here, and you haven't even specified if it's for a Mitsu or Garrett turbo. How can you think anyone here will seriously consider it?
Tim_K is offline
Old 09-25-2008, 06:56 PM   #7
My Ride: 87 shelby
1/4: 14.060
so ... i got what i needed from chris at turbos unleaashed and it says 87 dodge daytona above . i have the NHRA national record holder for 2003... what do you have?
Old 09-25-2008, 07:31 PM   #8
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Feedback: (36)
doesnt necessarily mean you still have the stock turbo - does it ?
detobias is offline
Old 09-25-2008, 08:45 PM   #9
My Ride: 87 shelby
1/4: 14.060
it is and it must be because the tech dept tears the engine down and checks everything on the motor and in the car.. that is what you have to go through to be awarded the NHRA national record
Old 09-26-2008, 01:31 AM   #10
My Ride: '89 plymouth voyager
Was that even a question? You want to run the 2.5" swing valve? That's the part that bolts to the turbine housing with the waste gate and the flange for the exhaust doughnut.
The real power comes from the '89 2.5" down pipe, not the swing valve. If you think you can get away with it, you can put on an '89 exhaust system, it goes right into the '87 one without any problems. You can find then on any '89 and up intercooled cars.
FWDPerformance.com
not sure if that will have the proper markings.
If you really wanted to make more power, you'd change out this piece
FWDPerformance.com
again, not sure about the rules.
tkelly27 is offline
Old 09-26-2008, 08:04 AM   #11
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
Hey duckky, don't sweat the grumps! we need pics of your car. like NOW!!!
dyno sheet
fmic install:
crazymadbastard is offline
Old 09-26-2008, 10:01 AM   #12
My Ride: 87 shelby
1/4: 14.060
t kelly thanks for the info ... and how do i post the pictures
Old 09-26-2008, 10:14 AM   #13
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
see where you type your mesages? click on the mountain icon above the typing area and insert the link for the picture there.
dyno sheet
fmic install:
Old 09-26-2008, 10:50 AM   #14
Feedback: (36)
well in that case you wont legally be allowed to run a 2.5" SV
maybe you can sneak a 2.5" DP by 'em
detobias is offline
Old 09-26-2008, 12:21 PM   #15
My Ride: '89 Lebaron GTC TII
Engine: TII 2.2
I think that he really wants us to know he has an NHRA national record. Hmm.
aerosmith145 is offline
Guitar Lessons | Loans | Credit Card Menu | Bad Credit Mortgages | Web Games
