Old 10-07-2008, 10:27 PM   #1
wastegate has never closed...
My Ride: 89 daytona shelby
Engine: Gas 135
hello everyone,
Well for 4-5 years now ive lived with the fact that i couldnt make boost faster than i could count but being the lazy person i am i didnt do anything about it as its too much work to take the turbo off...well recently i broke my cam shaft and had to take it off...and what do i find...the waste gate open when its supposed to be closed, i could actually see the opening of the hole with the waste gate "closed".
this is partially my fault for not understanding how turbos worked at the time, had i known id have sent it back along with my F'd up calibration. Also its the person/companies fault for doing some bad QA...i wont give out the name(s) of the parties involved as we all make mistakes and i dont wish to be flamed for bad mouthing a major contributor to the SD community.
But i think im going to have a good friend of mine weld the waste gate shut as i dont ever have it hooked up any way...any advice on the subject?
89'tonakickin is offline
Old 10-07-2008, 10:38 PM   #2
Re: wastegate has never closed...
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Feedback: (36)
instead of welding it shut (can you say "overboost"?) ...
how about fixing it, such that it functions as intended ?
detobias is offline
Old 10-07-2008, 11:42 PM   #3
My Ride: 85 GLHT, 87 ShelbyZ
you'll never be able to floor the car and wil hit overboost shut down if you weld the wastegate shut.
GLHNSLHT2 is offline
Old 10-08-2008, 09:20 AM   #4
Engine: Gas 135
when i had my stock turbo on the car i couldnt floor it with out monitoring the boost to prevent over boost shut down...im used to not being able to floor it to prevent over boost shut down. plus if i dont want an over boost shut down i can always put my bad calibration in the car which has no over boost shut down
i got 2 against welding the waste gate shut...1 for it being myself...
pending i can find a good job after i get out of school the motor is inline to get rebuilt right after the 4.6l DOHC from my mark 8 which i have yet to determine what type of forced induction i want.
Old 10-08-2008, 10:03 AM   #5
My Ride: '87 Daytona Shelby Z
Engine: 2.2l TII
Feedback: (6)
Images: 3
yeah don't weld it shut unless you are running an external wastegate
impuresoul2k3 is offline
Old 10-08-2008, 12:58 PM   #6
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
So you can blow it up??
speeduphoria is offline
Old 10-08-2008, 10:04 PM   #7
Engine: Gas 135
how much boost do u think these motors are capable of handling...only 20 psi, nope...as a matter of fact i know of a lil 2.5 daytona that ran for 2 years as a daily driver pushing 34 psi...im not saying anyone here dont know anything, just making a point that these engines r tough and will handle a lot
i have my waste gate disconnected from my vac system anyway...the only thing that will ever open my waste gate if i fix it is some extreme exhaust pressure cuz i have my waste gate arm pretty short...
i will look into other methods of fixing my issue but fixing the waste gate arm is looking to be more difficult than most realize...although either way i have to take the exhaust housing off...
ok whats the difference if i shorten my waste gate actuator arm to where it barely makes it to the waste gate arm versus welding it? is that not doing the same thing?
Old 10-08-2008, 10:53 PM   #8
we need pics of what is actually going on.
Old 10-08-2008, 11:16 PM   #9
Engine: 2.4 DOHC
if you weld it shut you cannot control boost, you get max boost that the turbo can make. This is not the safe level that the turbo can make nor is it what your motor can handle. You have to have enough fuel, cool intake temps and enough octane to run lots of boost safely.
Old 10-09-2008, 10:50 PM   #10
Engine: Gas 135
ok the 1st and 3rd are of the waste gate "fully" closed the second is fully open...the 4th is the aftermath of me taking the exh housing off...fun fun for me
Old 10-10-2008, 12:06 AM   #11
My Ride: 84 omni/90shadow es
Engine: 2.5 turbo/2.2 vnt
couldn't you just add a few washers to space the wastegate actuator out a little to get it to close all the way
84omni is offline
Old 10-12-2008, 03:14 PM   #12
My Ride: '92 Daytona Iroc
Is the puck shaft jammed? If so, have you tried freeing it up with solvent?
Andy
Austrian Dodge is offline
Old 10-12-2008, 03:38 PM   #13
Engine: Gas 135
the waste gate arm moves freely.the waste gate is always open it just wont shut...im getting it cleaned up as i type this...
washers wont do anything as far as i can see
Steven
Old 10-12-2008, 08:43 PM   #14
Steven
What is stopping it from sealing? It must be hitting something or the shaft is binding. The turbine housing doesn't appear to be clean/flat either. Is the puck hanging up on the debris?
Andy
Old 10-14-2008, 01:39 PM   #15
Engine: Gas 135
Well the broken bolts are finally out...just waiting to get the turbo back and ill see whats going on with it...hopefully it also got cleaned up...ill update asap
Web Advertising | Mobile Phones | Loans | Debt Consolidation | Bankruptcy
Page generated in 0.81839 seconds with 14 queries
