10-14-2008, 09:09 PM
Re: 89 dodge shadow psi question
My Ride: 1992 Dodge Daytona
Engine: 2.5l I-4 super 60
The turbo could be wearing out, but that should have minimal effect on how much vacuum the engine pulls.
Vacuum is typically read in inches of mercury, not pounds per square inch. At hot idle, you should have 18+ inches of mercury when the engine is hot and at idle.
We still don't know what guage you are using to verify these readings, so it is possible that there are some discrepancies in those readings. Low vacuum can be caused by several things ranging from incorrect camshaft timing, incorrect ignition timing, bad valves, clogged exhaust and I'm sure there's more that I cannot remember.
