Old 05-14-2003, 12:03 AM   #1
12psi on my t2?? stock??
i was told that on my 88 t2 5 spd daytona i should have 12 psi stock.......so my question is: im only hitting maybe 8-9ish tops on guage...is this normal? or whats the deal? i was plannin on 15 psi once i installed the manual boost controller but havent gotten that far.....oh also i was notciing a ton of lag....granted i need a new clutch cable so hard to tell which is the problem or which is more of the problem i should say turbo lag or cable......but.....hopefully next few days i will know......but please let me know on boost...i have car up for sale but i may just finish and keep it if it doesnt sell for what i want out of it
thankx
brooks
onenastymopar is offline
Old 05-14-2003, 12:20 AM   #2
12psi is stock, if your getting 8-9 psi, something is wrong. I know on my car that if i have a leak in my IC lines [front mount] that i usually only get 7psi and it has massive lag. Just a thought. Or it could be a vacuum leak.
89daytonaTII is offline
Old 05-14-2003, 08:05 AM   #3
hmm......i am gettin major lag but as i say its hard for me to tell what the problem is with there being multiple problems like clutch cable etc.....but i will have to check all fittings....anybody know of a way to check glued fittings? soapy water work ya think? and look for bubbles......or any better ways?
Old 05-14-2003, 03:08 PM   #4
i have heard from a few ppl that a propane torch around possible leaks will work. While car is idling (obviously) run the torch along the pipes or vacumm lines, aparently the engine will amke a noticable change in idle if a leak is present and draws in propane. I've never tries it but i can't see why it wouldn't work.
Old 05-14-2003, 07:25 PM   #5
My Ride: 88 Lancer Shelby
Engine: 4cyl. 2.5L
You could have a T1 computer in there.
LancerShelby is offline
Old 05-14-2003, 09:40 PM   #6
DaytonaVNT
otherwise, take a brake bleeder pump, and connect it to each hose... pump and you'll find your leak(if you've got one)
Credit Cards | Guitar Lessons | eHarmony Promotional Code | Credit Cards | Credit Cards
Page generated in 0.34914 seconds with 13 queries
