05-15-2003, 09:23 AM
Or, do it my way.
My way means getting another log manifold, cutting/grinding etc, until you can weld the spigot in a diff. direction so all the plumbing will fit.
-Aston
Yeah, I thought about doing that way, i've seen it on this webpage "Mike Dodge" Mike Dodge . I like the intercooler you have LARGE. FWD performance has turbo inlet fitting to connect IC hose to my booster...Looking at that other setup that I mention., yeah the turbo looked like maybe a Mitzu Booster unit. I Just installed an G-valve and is setup for approx 13psi and it works real good, and it doesn't hit the cutout limiter. (set at 14psi at first and it did cutout, so readjust to 13). Question>will a upgrade Stage 2 ECU, ( which rates of going to 14 psi), I could go with that in place of the G-valve, Or does it reduce boost after few sec. for a protection? Want yours do?
