I actually own an 89 Spirit 2.5 T1 (mitsu turbo) .. was hoping you could help me with injectors/boost/turbo/etc...
What I am wanting to do by late june is add an intercooler and raise my boost from stock (I believe 7psi) to 14psi.
I will be junkyard hunting looking for an intercooler, blow-off valve, and anything else you guys might suggest.
Anyways my main questions are as follows:
Can I raise boost to 14psi safely with no major mods? Will my injectors work at 14psi or will I need different ones?
What exactly is involved in raising the boost to 14psi? What lines will I have to tap/bleed etc?
Will my computer/fuel pressure regulator make up for the difference in fuel requirements from the 7 to 14psi boost jump or will I need something else new? (pressure regulator, fuel pump, etc?)
And are there any other major concerns?
If you guys can give me as much specific information as possible I would appreciate it =) I will go to the junkyard and hunt for what is necessary and buy what I cannot find at a junkyard. So please be as specific as possible! Thanks guys!
http://kcar.mine.nu/
