Old 05-17-2003, 08:14 PM   #1
"Priming" a turbo???
I just put the turbo back on my engine after it being off for nearly a year. Do I need to "prime" it with lubricant to help prevent damage when I first fire it up? If so, how is this done?
mcaracter is offline
Old 05-17-2003, 09:45 PM   #2
My Ride: 88 Lancer Shelby
Engine: 4cyl. 2.5L
Just pull the plugs and crank the engine until you see oil pressure. Then install plugs and boost away.
LancerShelby is offline
Old 05-17-2003, 11:03 PM   #3
Can you just disconnect your injector harness?? Thats what I did when I primed my new turbo.
shelbyglhs222 is offline
Old 05-17-2003, 11:42 PM   #4
My Ride: 87 LeBaron Convert
Engine: 2.2 Turbo 2
I am guessing that as long as the turbo isn't actually spooling at all during it's first dose of oil you are fine - however you want to keep the cylinders from firing is fine I imagine. I imagine doing the harness & the plugs would be best to keep from flooding the engine with gas =)
89DodgeSpirit is offline
Old 05-18-2003, 02:13 AM   #5
you can also just disconnect both plugs on the hep. no signal to computer, and it kills spark AND gas. thanks per.
tony
macncheese is offline
Mobile Phones | Credit Counseling | Mobile Phones | Credit Cards | Php Scripts
Page generated in 0.34438 seconds with 13 queries
