Old 05-20-2003, 09:13 PM   #1
Grainger Valve Shakes
newtomopar
I installed a Grainger valve in my '90 Daytona and the whole car gets the shakes when the boost gets to it's top level. If I take the G-Valve out, it runs normal.
Any ideas as to what is going on?
Old 05-21-2003, 02:07 AM   #2
r3mix
Do you have an Air/fuel gauge installed?
Old 05-21-2003, 02:16 AM   #3
maybe the extra power makes your car shake. Is the g-valve set at the same psi as stock???
89daytonaTII is offline
Old 05-21-2003, 08:19 AM   #4
newtomopar
Yes I have an air/fuel gauge installed and I see little change with the addition of the G-Valve.
I set up my G-valve just as described in http://www.xmission.com/~dempsey/perform/grainger.htm.
Do I really need the small vent to atmosphere?
Old 05-21-2003, 08:42 AM   #5
My Ride: 1987 Sundance
Yes!!!! If you don't have the vent to atmosphere, the boost signal to the wastegate actuater will keep the wastegate open. The restrictor vents this pressure signal to atmosphere when the boost level drops.
Guy Douglas
guyd_15 is offline
Old 05-21-2003, 03:08 PM   #6
r3mix
I didn't have a drill so I did my vent hole a different way.
I just put a T in the hose as close to the grainer as possible. A very small T. Works fine. I hope that fixes your problem.
Old 05-21-2003, 03:37 PM   #7
newtomopar
I already have a vent right after the grainger valve.
Maybe it is just the waste gate trying to keep up and it cycles rapidily. I don't know but it is annoying.
Old 05-22-2003, 01:52 PM   #8
"the whole car gets the shakes when the boost gets to it's top level"
I'm not sure what you mean by "top level" do you have a boost gauge? What pressure is it reading at "top level"? You may be hitting overboost, which gives a stuttering or shaking feeling.
Guy Douglas
guyd_15 is offline
Old 05-22-2003, 02:26 PM   #9
when i hit overboost cutout, it feels like i'm hitting a wall, but i have heard that the earlier years were a little softer than my 89.
Old 06-13-2003, 11:27 PM   #10
Unhappy
I'm having the same problem... and I'm not hitting "a wall" it just sputters and vibrates at max boost. My car's an 88. I've hit overboost many times when I first installed it, but now it just sputters. I can't go over 120km!!!
ieatrice is offline
Old 06-14-2003, 03:03 AM   #11
My Ride: 1984 Daytona
Engine: 2.2L Turbo 1
Old cars hit overboost shut down hard too. my 84 has ripped several front mounts from hitting overboost unexpectidly. My car does a similar shudder on part throttle accel going down the freeway. @ aroung 5psi it shakes and hesitates, if I give it more throttle it smoothes out. I don't do much part throttle accel, WOT or brakes baby! So I really don't worry about it. Is you A/F guage showing Rich or Lean when when it does this? could be a lean miss fire? Clogged fuel filter? Fuel pump going out? Just an idea hope you figure it out.
SwiftTech is offline
Old 06-14-2003, 03:51 AM   #12
My Ride: 87 LeBaron Convert
Engine: 2.2 Turbo 2
just a thought - the added torque/power ... transmitted partially thru the motor mounts. I know that my car has bad mounts and if I go into any boost over like 3psi my loose door panels rattle and I can hear it - the whole car shudders a little albeit not violently.
I am willing to bet new motor mounts would alleviate most of this vibration/shuddering. Check your mounts - if they are bad replace them.
I recommend the Quickor urethane ones =)
89DodgeSpirit is offline
Old 06-16-2003, 12:15 AM   #13
For me, it feels like there's a leak or the fuel shut off or something. Not really a vibration, just rapid fluctuations in power.
ieatrice is offline
Old 06-17-2003, 03:04 PM   #14
Anyone?
ieatrice is offline
Old 06-17-2003, 03:30 PM   #15
Show me your g-valve
Lebaronguy2001's Avatar
My Ride: '89Baron, '04Stratus
Images: 19
replace fuel lines and filter?
Lebaronguy2001 is offline
Bankruptcy | Bad Credit Mortgages | Debt Consolidation | Movies download | Free RPG
Page generated in 0.44217 seconds with 13 queries
