Old 05-28-2003, 01:18 PM   #1
Question Hybrid - Is T3 57 trim too big, and must it have a T3 stage 3 trim turbine??
My Ride: 2004 eBlue SRT4
Is a 57 trim T4 compressor housing and wheel too big for a 2.5L with 5 speed??
Does this T4/T3 hybrid set-up mandate having a stage 2 or 3 turbine T3 wheel (inside a .63 housing)??
I am guessing that this would be a dog on the street, but OK for a light weight race only car.
Anyone who has run the set-up please comment.
I am looking for some first hand feedback.
Regards
Jeremy
jbarlow is offline
Old 05-28-2003, 01:39 PM   #2
Question Correction - Hybrid T4 57 trim compressor to big, and must T3 stage 3 turbine be used
Correction
The title and body should have read...
"Is T4 57 trim to big, and must a T3 stage 2 or 3 turbine wheel be used (with 0.63 turbine housing)??
Regards
Jeremy
jbarlow is offline
Old 05-28-2003, 04:12 PM   #3
My Ride: 1989 Shelby CSX
Engine: 2.2 16v Hybrid
57trim is really big and not needed for a daily driver imo...if you're looking for a hybrid look towards the 50, super 50 or super 46 trim hybrids w/ a stage II wheel....but you'll be better off spending your money elsewhere to start (nice intercooler/exhaust) then replace the turbo and port the exhaust manifold while its out. good luck.
Scott
scott is offline
Old 05-28-2003, 05:16 PM   #4
Please tell me what the 'Super' means. What makes it any different the usual 50, 46, or whatever trim?
Shelby VNT is offline
Old 05-28-2003, 06:53 PM   #5
check out the compressor maps:
46 Trim:
http://www-unix.oit.umass.edu/~sdean...046%20trim.bmp
Super 46:
50 Trim:
http://www-unix.oit.umass.edu/~sdean...050%20trim.bmp
Super 50:
54 Trim:
http://www-unix.oit.umass.edu/~sdean...054%20trim.bmp
Super 54:
sorry some of the maps are small
Scott
scott is offline
Old 05-28-2003, 07:53 PM   #6
My Ride: 1991 Spirit R/T
The "Super" designation means the wheel has a larger major diameter with the same inducer size. Technically, this changes the actual trim designation (since trim is calculated based on dimensions), but Turbonetics ignores that
As as example in the TO4E 50 trim:
The "regular" 50 trim uses a 2.122" inducer with a 3.000" major diameter.
The "super" 50 trim uses the same 2.122" inducer diameter with a 3.200" major diameter.
Since the inducer is what determines maximum flow rate, both wheels are rated at 47 lb/min (about 450-475 hp) maximum. The advanatge to the "super" wheels is the larger major diameter moves more air at a lower rpm (i.e it should spool faster). I was skeptical of this at first as I though that the larger inertia of the larger major diameter wheel would more than overcome the ability to move more air at a lower rpm and thus cancel the faster spool up potential. I cant say for sure if the "super" spools any faster than the "regular" wheel, but on my R/T, the TO4E "super" 50 trim / Stage 3 / 0.63 turbo comes on alot sooner than I thought it would.
4sfed4 is offline
Old 05-28-2003, 08:01 PM   #7
Formula for calculating compressor trim:
trim = (inducer diameter)^2 / (exducer diameter)^2 x 100
Thus, for the "regular" 50 trim:
trim = (2.122^2) / (3.000^2) x 100 = 50.03 = 50 trim
For the so called "super" 50 trim:
trim = (2.122^2) / (3.200^2) x 100 = 43.97 = in reality a 44 trim
4sfed4 is offline
Old 05-28-2003, 09:26 PM   #8
Wow Larry, thanks for the information! So it looks like I should be looking at a Super 50 actually. Cool, learn something new everyday.
Old 05-28-2003, 09:29 PM   #9
Cool Gonna stick with the 60 trim instead of hybrid!
Thanks for the feed back!
I was presented with a good buy, but following the feed back I've recieved, and other good advice, I'm going to pass up the offer, and stick with my 60 trim T3 instead.
I'll probably be happer on the street with that.
I had considered keeping that for a race only 2.5 Omni project, but it may even be too much for that!?!
Jeremy
jbarlow is offline
Old 05-28-2003, 10:56 PM   #10
No prob. Id highly recommend the Super 50 trim. Anyone I know that has used it has been quite pleased. Its a very good match to our engines and can flow enough air for 99.999% (in reality probably 100%) of the Turbo Dodges out there.
4sfed4 is offline
Old 06-03-2003, 02:59 AM   #11
how does the super 50 compare to the super 60?
boostaholic is offline
Old 06-03-2003, 10:02 AM   #12
There are a couple of "Super 60" wheels.
The one you are probably referring to is the common T3 "Super 60" trim compressor. This is much smaller than the TO4E "Super 50 trim" wheel.
There is also a TO4E "Super 60" trim wheel as well. Its a relatively huge wheel and probably not a good match to most TDs.
4sfed4 is offline
Project cars | Internet Advertising | Loans | Debt Consolidation | Mortgages
Page generated in 0.43450 seconds with 13 queries
