05-30-2003, 11:27 PM
My Ride: 87 LeBaron Convert
Engine: 2.2 Turbo 2
seen that, tried that, no luck
The vacuum line that is going to the stock BOV doesn't seem to be on this diagram... either that or I am blind...
I know where the line I am looking for T's off of... but when I go there and go to the T it runs to two dead ends that are capped off...
So I have a broken vacuum line on a quick release valve but I cannot find the other end of the broken line anywhere... From the way the old line is molded from heat I can tell it ran down and behind the box and then to the left somewhere but I cannot find where...
I had my headgasket done not too long ago and they had to undo and redo all of the vacuum lines so it may be that this broken vacuum line was simply removed or a T was added with a cap or something I really have no idea... But the two lines I foudn with caps look to be original from the factory...
So I need somebody please to go thru the effort of tracking this small little line for me.
Or at least giving me some insight on how to find a vacuum leak... I tried spraying a mist of water at all the lines and no results from that...
I am only getting 3/4 PSI boost on my wastegate line, 3/4 pounds of boost on my Throttle Body small line, 3/4 PSI boost on my brake booster outlet hose during boost... And that is rarely (only when I floor it)
So basically I am running a non-turbo MPI 2.5.... Not exactly my idea of a Turbo Dodge.
Sorry if I seem upset - I am - I want to fix this so I can install my G-Valve and up my boost and install my intercooler & new BOV I have sitting here in the floor behind me.
It was suggested to me that maybe my intake manifold gasket is bad/removed because I recently had headgasket done by a shope and maybe they didn't replace it... Well I am getting 19 inches of vacuum off the Manifold side of the throttle body at idle so I think that my seals between the engine and the TB are good otherwise I wouldn't be getting 19/20 inches of vacuum...
My problem is in the boost going from the turbo to the TB somewhere... It is leaking out of a line that is dedicated turbo (like the wastegate line is... it never sees vacuum) Otherwise my vaccuum at idle would not be 19" (boost leak causing lower boost - vacuum leak would cause lower vacuum as well)
Anyways there is a vacuum line that goes to the "Quick release air valve" right outside the airbox and from that it runs inside to the big plastic junky stock "BOV"... The big huge "vacuum" line from the "BOV" in the airbox that goes to the turbo is good... I pulled it off to feel about 2/3psi... Now the little vacuum line is broken and I cannot find it's origin... Since it is a source of pure boost I am guessing that it could be my leak that I am experiencing. (AKA Open Blowoff valve AKA massive boost leak AKA no Turbo Boostin)
Now if somebody could please take the time and trouble to trace this little line for me I would GREATLY GREATLY GREATLY appreciate it! I will do whatever is necessary to get my car boosting again just short of paying money (because I have none)
So if you can help me out PLEASE *I BEG YA*
Thanks!
Mike
