06-02-2003, 11:44 AM
Largest/best turbo for stock location?
The title says it all. I am looking for the best flowing turbo for an 8v 2.2 liter engine that will fit in the stock location. I have an L-body, so I am not sure about clearance problems with other setups. Any advice or info appreciated. The car is going to be modded to the T. It will be running about 21 psi. It will have all of the usual goodies. Huge front mount IC, 3inch exhaust from turbo back, ported everything, max flow FB head with big valves etc. No expense to be spared. It will also have a hybrid 568 tranny with a quaife and 3.50 FD. Also if someone has the setup I am looking for, where did you get it and do you have a part#? Thanks, Pat
