06-27-2003, 08:02 AM
My Ride: 1987 Sundance
I believe your talking about the exhaust turbine housing, right? If you are removing both the compressor and exhaust turbine housings the first thing to do is mark both housings and the center section so when you reassemble the unit the housings line up with your intake and exhaust plumbing (I use a center punch, that way the marks aren't accidently removed). You said the one bolt was hitting the fitting on the center section, is it one of the bolts holding the flat housing clamp in place? If it is, tighten it up a little so it's not hitting the fitting. Soak the parting line between the center section and the turbine housing well with penetrating oil and let it sit for a couple hours. Then taking a hammer lightly tap on the turbine housing, going around it in a circular motion (so it doesn't get crooked and jam) until it loosens from the center section, now you can rotate the bolt so it is out in the open.
Hope this helps, Don't forget to mark the orientation of the housings.
Guy Douglas
