Old 06-19-2003, 07:53 PM   #1
i wanna put a 3inch DP on and isntallation
can i do this on a stock mits out of a 90 Shadow T1 2.5 5sp
it looks to have a 2.5 right now, i can afford to upgrade turbo or i would do that, so can i do this, if so, how should i go about doining it? will a 3" DP from FWDPerformance fit up to a mits?
let me know, im reaplaceing exhust with a 3" so i would prob rather do this at same time, and it i do, can a DP be put on from bottom of motor, or do i can to pull intake off?
let me know
Rich
V8GremlinX is offline
Old 06-20-2003, 01:05 AM   #2
My Ride: 1989 Shelby CSX
Engine: 2.2 16v Hybrid
yes you can do it no problem but your boost will be uncontrollable...it will creap to cutout no matter what your starting boost is...but i suppose there are worse problems =p
--scott
scott is offline
Old 06-20-2003, 09:49 AM   #3
why would it creep to overboost?
if i buy a aftermarket ECU, will it eliminate the overboost?
i already have problems with it hitting overboost before my shift point
Rich
Old 06-21-2003, 07:14 PM   #4
it creeps because the pressure differential is too great...there is nothing you can do about it except get a bigger turbo...but is that so bad?
scott is offline
Old 06-22-2003, 12:48 AM   #5
what can remove the overboost?
i would jsut do that till i can afford a garret T2 ot T3
Rich
Old 06-22-2003, 08:39 AM   #6
well you can keep your foot off the gas to avoid the overboost ;]...but that's really about all you can do except add a diode or get a custom cal that allows you to see more than 14.7 psi and try to take advantage of the "overboost"
--scott
scott is offline
Bad Credit Mortgages | Advertising | Mortgage | Debt | Final Fantasy Concert
Page generated in 0.28517 seconds with 13 queries
