Old 06-20-2003, 07:25 PM   #1
Help no boost
pmrod
does changing my fuel pump and raising my static fuel pressure to 48 psi , ive got +20 injectors have any thing to do with losing all boost. was working good until i changed the fuel pump. how i check if there is something else causing me not to have any boost? !!!!!!!!!!! Help...........
Old 06-20-2003, 10:53 PM   #2
My Ride: 87 LeBaron Convert
Engine: 2.2 Turbo 2
unhook the wastegate vac line and go for a quick run - if you get boost - then something is wrong with the can =)
89DodgeSpirit is offline
Old 06-22-2003, 10:35 PM   #3
no boost
pmrod
hey, hybrid thanks for the info. I went straight to the can like you suggested and found that the mounting bolts had backed off quite a bit. in fact they were almost off. tightened them back down and lo n behold my car is running great. Thanks alot for the info.
Loans | Bad Credit Mortgages | Mortgage Calculator | Personal Loan | Mortgage Calculator
Page generated in 0.40843 seconds with 13 queries
