Old 06-25-2003, 06:10 PM   #1
Lightbulb I get boost in N
T2Daytona
Never noticed the car doing this before, but it's recently started getting into boost if I rev it up good in N. I hit about 5psi. I think I could've hit more, but I didn't wanna break it lol
What's up with this?
2.2 T2 A555
Old 06-26-2003, 10:42 AM   #2
T2Daytona
18 views and no one can help??!!
Old 06-26-2003, 12:55 PM   #3
Hum???
Tom Powell
That is odd, needs load to boost. Like the load of working to move the car. I can get mine right to zero but that is it. I read somepace that the turbo chryslers/dodges were limited by the logic module on boost till the car was going a certain rpm (don't rember how many)@ 5-10 mph or more. Trying to prevent people from damageing the transmission. However that was pertainiing to t-1 cars. Don't know about others.
Check vacuum lines would be my sugestion. Codes?
Old 06-26-2003, 01:00 PM   #4
Re: Hum???
T2Daytona
No codes vac lines are all good.
It makes 5psi parked in N or in gear just sitting if i rev it to about 5k or so
Old 06-26-2003, 01:07 PM   #5
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
Normal, especially if you have intake and exhaust mods. Our turbos spin even at idle, so that helps too. I noticed that after I installed a "D-valve" I could very easily build up to around 5-7 psi revving while parked. Kinda pointless, but no worries. It doesn't take that much revving to get the BOV chirping at idle either.
iTurbo is offline
Old 06-26-2003, 01:27 PM   #6
T2Daytona
Car is stock right now
How come it never did this before?
Old 06-26-2003, 01:37 PM   #7
Timing belt slipped?
lametec is offline
Old 06-26-2003, 02:02 PM   #8
T2Daytona
I believe it is off a tooth or 2, but it's been that way since I've had it and this just started
Should I even be worried about this boost issue?
Old 06-26-2003, 02:28 PM   #9
I you know the timing belt is off, I wouldn't worry about the boost issue. I would worry about the timing belt being off, though.
lametec is offline
Charity | MPAA | Debt Consolidation | Debt Consolidation | Travel deal
Page generated in 0.36652 seconds with 13 queries
