07-03-2003, 11:24 AM
My Ride: 89 Caravan
Thanks Turbulence and 87Shelby.....
I got out there this morning and checked the belt. Sure enough it was one or two tooth off. I timed it right and now it pulls all the way to redline. "thumbs up It even got rid of a horrible vibration when under load!
Only thing I still need to do is dial in the ignition timing. I took the distributor out to verify the timing as per the directions. It looked to me to be a little too advanced, but I can not verify it till I get a timing light, so I just adjusted it best I can by ear.
I was able to do the operation myself using a tent stake to pry on the tensioner to get the belt set while I tightend the tensioner nut. I had to do it a few different times but now its pretty close.
I did loose low end torque on the bottom, but it pulls all the way up now.
Again thanks guys, who knows how long it would have took me to find the problem without your help,
Jeff
