Old 06-30-2003, 08:33 PM   #1
one last time!
89turbovan
been tryin to figure my 89 turbo van out, it just has no balls!!! but goin down the highway at 65 it runs fine, just under acceleration. its rough, and no get up and go. It's all stock, not sure if the turbo is even working! any help is greatly appreciated.
PS. it's got real bad fuel milage.
thanks
Old 06-30-2003, 08:38 PM   #2
do you have a boost gauge? you might need to get one and see if your turbo is pushing out anything,or you might have a vac leak somewhere under hood,check the vac line from the wastegate to the turbo,see if thats needs reeplaced try to touch any and all vac lines to see if any of them are broken or will break,if they are hard and plastic like replace them.
Adidasmjo is offline
Old 06-30-2003, 08:57 PM   #3
RECORD HOLDER 11second mini
gasketmaster's Avatar
1/4: 11.760
Have you checked for trouble codes?
Could be many things but if your fuel mileage is really bad I would go for the O2 sensor.
gasketmaster is offline
Old 07-01-2003, 04:54 PM   #4
My Ride: 1987 Shelby GLHS 189
yep yep yep....
glhsken is offline
Old 07-02-2003, 01:28 AM   #5
My Ride: 1986 Shelby Charger
Engine: 2.2 SOHC
Cam timing?
GLHandGTS is offline
Old 07-05-2003, 12:03 PM   #6
Talking
89turbovan
yeah think im going to look into the cam timing first then others. I got to get this thing runnig right! Thanks for the help guys!!!:big grin:
Old 07-05-2003, 04:28 PM   #7
My Ride: 89 Caravan
I had same problems... 1st I swapped in a new HEP, it helped some but it still lacked... checked the cam timing and sure nuff, it was off, fixed it and now I got a healthy 12 lbs of boost!
Jeff
My96z is offline
Debt Consolidation | Debt Consolidation | Problem Mortgage | Debt | Moneygram
Page generated in 0.55137 seconds with 13 queries
